aluminium dual core radiator
I have one, works fine for me on track, would imagine it would be more than upto the job for a road car. Cant remember the make, they all probably come from the same factory. The cap that came with it wasn't much cop mind so I'd replace that.
Was it this one matey?
http://pages.ebay.com/link/?nav=item.view&id=201271424558&alt=web
I have a genuine HKS cap should fit.
there to good for on the road they cool to much !!! i used to have a mitsumisho twin core rad i had al sorts of cooling isseus ( being to cold ) so swapped over to a small single core rad and is perfect again
I had no problems on the road and through winter with a standard thermostat, measuring the temp with a defi gauge too. That was a 40mm thick but I think just single core one.
Heats the killer, mine works fine atm but it's off the non turbo ep91 I just have little worries running hybrid with it been thinner, the civic rads are the in thing easy to work with out the way neatness but they have no shroud and my cooling panel will have to go as it holds no purpose if I have the cash payday Lews SARD rad is mine lol
