guessing you have adjusted the idle screw on the tps mate? think its there anyways
failing that my revs are wherever it likes at the moment, its had a tps so im planning on changing the idle control valve to see of that helps with mine.
Check all the lines first for vacuum leak, remove intercooler pipe and stick your finger over the little holes inside the throttle body
If you block off wax stat, then you will need to loop the coolant line it uses,
remove the wax stat and block it up with some epoxy putty.
Pulled the vac line out of the Map sensor and the revs dropped from 1600rpm to a healthy 800rpm, exactly how it should be.
so bought another Map sensor earlier and that should sort it.
its weird because when I rev it with the vac line plugged into the Map sensor, at 4000rpm the EML will come on and stay on until I turn her off.
then if I pull out the vac line and rev her up, no EML so aye, moneys on this existing Map sensor bein fucked
