You can setup EMU to use the launch only once. If you want to use it again, you have to activate it again with a laptop. IMO you can't make it work with a switch.
Edited by JayJ
No I'm pretty sure it's not a viable option to have it on a switch. All the Link and haltech is no problem for a switch but 99% you can't on the EMU
Im sure there is a way. As a person i knew had a emu. And he coukd activate his launch control through his high low boost button
