Jhandy Posted April 25, 2015 Posted April 25, 2015 Hey guys. I have just fitted a tial external wastegate today. And for some reason ita not opening. I have been told it has a 0.8 spring in it. But its nearly boosting to 1.9 bar. So at the minute. Im staying out the boost range. I have switched my boost controller to externak wastegate. And all the vacum pipes are on the right way. Anybody have any idea Quote
Matt1878 Posted April 25, 2015 Posted April 25, 2015 Renove the vac lines to the EBC and just run a line from the top of the wastegate to the turbo... This will make sure the spring is a 0.8 spring. Quote
Gainzy Posted April 25, 2015 Posted April 25, 2015 If it's a jizzmo just throw it out the window lol Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Ok will try. And its a greddy profec-b Quote
Gainzy Posted April 25, 2015 Posted April 25, 2015 Good choice, yeah chance's are it needs set up again Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Well at the minute. I have lowered every dial to its lowest i may as well just not have a boost controller lol. Will go have a play in a min Quote
tommyep82 Posted April 25, 2015 Posted April 25, 2015 Is wg on the right way pal Alan key bolts go to screemer exist side Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 As in the side with the thread. Yh thats were the screamer is bolted Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Ok just been out. Disconnected vac lines and ran it from the turbo to the top of ewg. Still exactly the same. Boosting up to about 1.9 bar. Anymore ideas Quote
Matt1878 Posted April 25, 2015 Posted April 25, 2015 So you have removed all the lines from the EBC solenoid and they are now running to nothing?If so, I'd be checking the spring/s in the wastegate and making sure it is 0.8bar spring Quote
RobSR Posted April 25, 2015 Posted April 25, 2015 Renove the vac lines to the EBC and just run a line from the top of the wastegate to the turbo... This will make sure the spring is a 0.8 spring. Brilliant advice Leave the top port open and run the vac line from the side port on the waste gate, to a boost source ideally your turbo compressor housing. That will then run it off spring pressure. You only use the top port aswell when running with an EBC so don't use it for the moment to rule that out. Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Yeah they where just laying there doing nothing Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Good choice, yeah chance's are it needs set up againOk will try this Brilliant advice  Leave the top port open and run the vac line from the side port on the waste gate, to a boost source ideally your turbo compressor housing. That will then run it off spring pressure. You only use the top port aswell when running with an EBC so don't use it for the moment to rule that out. Quote
RobSR Posted April 25, 2015 Posted April 25, 2015 (edited) Let me know how you get on EDIT - also what tial gate is it a F38 or MV-S gate? As there is a port on the side at the top of the MV-S that isn't the one you want to use. You need to use the lower port near the bottom. Edited April 25, 2015 by RobSR Quote
Ollieh17 Posted April 25, 2015 Posted April 25, 2015 Definetly a 'air port' you have a vac line going into and not a 'h2o' port? I know some tials are watercooled Quote
RobSR Posted April 25, 2015 Posted April 25, 2015 Okay just the port on the side then and it'll be fine. Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Ok that worked. Its 0.8 every an i ding wrong Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Basically i have now routed the top port from the wastegate to the in port on my solenoid and my out port is venting Quote
RobSR Posted April 25, 2015 Posted April 25, 2015 (edited) I thought you wanted it to run .8 bar spring pressure lol? If you want your Boost controller fitted right and you have a profec you want the COM port to go to the top of the wastage and the NC port t-pieced into the vac line that runs from the turbo housing to the side port on the waste gate Edited April 25, 2015 by RobSR Quote
Jhandy Posted April 25, 2015 Author Posted April 25, 2015 Thats how i originally had it.but it wasnt working Quote
