mikey4410 Posted April 30, 2015 Posted April 30, 2015 so as a few of you know I did brands yesterday and my front mount intercooler thats the size of the stock topmount was hitting temps of 44 degrees and stayed there for everytime I was out.it peaked at 50 degreesthis is way to high for my liking. question is what will fit under my na bumper but be big enough to keep my temps to a safer level please.any help/suggestions and or pictures of yours would be gratefully received.thanks Quote
maddox710 Posted April 30, 2015 Posted April 30, 2015 50 isn't that high really Mike, you could try getting the hot air from out the engine bay quicker, could drop It abit just by reducing heat soak Quote
mikey4410 Posted April 30, 2015 Author Posted April 30, 2015 the coolers right out butted up to the inside off the bumper so well away from radiator, also the rad fan blows into the engine away from the cooler. Quote
morgey Posted April 30, 2015 Posted April 30, 2015 Im sure i read that Youre actually better having no gap between the ic and the rad as the air that passes through the ic then buffers/swirls and creates a barrier Between the both of them. Quote
AdamB Posted April 30, 2015 Posted April 30, 2015 Nothing wrong with those temps mate, when you start getting to 60-70 degrees that's when engines don't like it and it becomes increasingly harder to control detonation without using exotic fuels. What I would suggest is getting a temp probe and sticking it after the turbo, but before the intercooler. That will give you a good estimation of how efficient your intercooler is. Can do a simple sum... (T2-T1) *100 will give you intercooler efficiency. Where T2 is the temperature after intercooler, and T1 is before intercooler Quote
mikey4410 Posted April 30, 2015 Author Posted April 30, 2015 adam and morgey ure inputs are greatly appreciated.thanks so muchly. :-D Quote
5e colin Posted April 30, 2015 Posted April 30, 2015 simple job fit a nozzle infront of the cooler and spray water on it wile racing hard the temps will plumit bigtime !!!! :) or lift of ha ha Quote
Arnold Posted April 30, 2015 Posted April 30, 2015 How are you measuring your intake temps mate? Quote
mikey4410 Posted April 30, 2015 Author Posted April 30, 2015 a digital temp guage with a probe that sits inside the cooler Quote
Rob H@RCH Engineering Posted April 30, 2015 Posted April 30, 2015 Im sure i read that Youre actually better having no gap between the ic and the rad as the air that passes through the ic then buffers/swirls and creates a barrier Between the both of them. This is very true! even better is to have something like a door seal/ draft excluder sealing them together too so the fan pulls the air through the cooler then the rad! I carnt do this tho as my fans on the wrong side lol Quote
