german4efte Posted May 3, 2015 Posted May 3, 2015 (edited) Hican somebody tell if the OEM LSD diff from MR-2 fits in a Glanza gearbox? think its also an C-family gearbox.would such LSD stand Glanza with 180PS-190PS ? ths MR2 LSD also got 8 bolts like glanza DIFF WHAT IS THIS FOR AN KIT?http://www.mts-motorsport.com/PhantomGrip-LSD-Kit-TOYOTA-STARLET someone used it? Edited May 3, 2015 by german4efte Quote
morgey Posted May 3, 2015 Posted May 3, 2015 Theres mixed ideas on whether the mrs diff will fit. Personally i would say it would as its a C series box like the V is And they both use the 8 bolt ring gear too. the corolla tsport boys all use the mrs lsd and they put out 190hp stock but its the torque that would be the issue but i doubt it would be much of a problem tbh. The phantom grip is a make shift lsd for a open diff. Have a look on youtube at how they work iirc they opperate more like a 2 way which isnt great for a fwd car Quote
german4efte Posted May 3, 2015 Author Posted May 3, 2015 thank you, the torque could be problem, dont realy know what my car gots. I use tongs CT9 and mapped MAX 1,2 bar for short overboost with 370cc injectors....it feels like much torque, would be bad if the OEM N/A diff break. This damage my complete gearbox The phantom grip seams shit...dont realy believe this can work. Some honda drivers use it an got bad damages (google said) Quote
5e colin Posted May 3, 2015 Posted May 3, 2015 your not going to blow the oem lsd with a tiny ct9 oem lsd are very strong what na box you have ???? there 6 bolt Quote
german4efte Posted May 3, 2015 Author Posted May 3, 2015 i got a corolla AE110 5 speed and fitted an 4e bell at the gearbox. i have a 8 bolt diff. i dont use OEM CT9 use hybrid... Quote
Stu Posted May 3, 2015 Posted May 3, 2015 Yep you don't want a 2way LSD in a FWD - decel cornering = spear off the road if your not careful. Quote
german4efte Posted May 4, 2015 Author Posted May 4, 2015 and what kind of LSD is a torson? I know how it works, but does it also lock when i roll in coasting mode?? or is a torson no problem at FWD car? Quote
pockrockgtti Posted May 4, 2015 Posted May 4, 2015 the mr-s lsd wont fit the c52/56, it has different dimensions its too big, the diff bearing are a different size and also the number drive shaft splines are different 20 vs 23. The bolt spacing of the ring gear is also different Quote
german4efte Posted May 4, 2015 Author Posted May 4, 2015 (edited) @pockrockgttithank you for these accurate post. you tryed it? this is no good answer for me, but so i can save the re-shipping if your sure i watched at TRD lsd page, these also got different TRD numbers. So i think its for sure that this wont fit :-( Edited May 4, 2015 by german4efte Quote
pockrockgtti Posted May 4, 2015 Posted May 4, 2015 it wont fit. If you buy this http://www.ebay.co.uk/itm/TOYOTA-LEVIN-TRUENO-BZR-AE111-20-VALVE-SUPERSTRUT-6-SPEED-GEAR-BOX-WITH-LSD-/251916224832?pt=LH_DefaultDomain_3&fits=Car+Make%3AToyota&hash=item3aa7608940 the lsd out of this box will fit a c52/56 this is what i have used in mine Quote
german4efte Posted May 4, 2015 Author Posted May 4, 2015 this gearbox is already found....price is ok, but what should i do with the 6 speed gearbox....dont realy want fo put it in my corolla, the gear ratios are not so good in my opinion, i always have to shift....i`ll think about thank you for your help Quote
morgey Posted May 4, 2015 Posted May 4, 2015 6 speed box is one of the best mods in my 20v corolla. Just miss 5th if you're being lazy but when you want to have some fun they make the car so lively You will need to mod your shifter assembly to allow the extra travel over into reverse Quote
pockrockgtti Posted May 4, 2015 Posted May 4, 2015 this gearbox is already found....price is ok, but what should i do with the 6 speed gearbox....dont realy want fo put it in my corolla, the gear ratios are not so good in my opinion, i always have to shift....i`ll think about thank you for your help just take the lsd out of the 6sp levin gearbox and put it in a 5sp c52/56 thats what i did Quote
morgey Posted May 4, 2015 Posted May 4, 2015 just take the lsd out of the 6sp levin gearbox and put it in a 5sp c52/56 thats what i didI have also done this on my other car. Taggy did a how to on swapping diffs on these. Quote
Taggy Posted May 13, 2015 Posted May 13, 2015 Yeah take a look in the howto section, its in there Quote
Phil Posted May 14, 2015 Posted May 14, 2015 Yeah take a look in the howto section, its in there link me ive looked and feel blind. i must be looking right at it. Phil Quote
morgey Posted May 14, 2015 Posted May 14, 2015 Here you go.http://www.ukstarletowners.com/topic/59358-a-guide-to-fit-an-aftermarket-quaife-lsd/ Quote
Phil Posted May 14, 2015 Posted May 14, 2015 Here you go.http://www.ukstarletowners.com/topic/59358-a-guide-to-fit-an-aftermarket-quaife-lsd/ so its just the same as fitting any other gearbox? also does the ae111 superstrut gearbox fit straight on the a 4efte engine/driveshafts? or is it not suitable? phil Quote
morgey Posted May 14, 2015 Posted May 14, 2015 Yeah the ae111 lsd is an internal lsd so you use all of your none lsd parts to fit it. And the levin 6 speed box doesnt have the 3 bolt holes in the front of the box for the mount but you could strip your 5 speed box and put the 6 speed internals into your casing then just bolt the 6 speed endcasing on to house the extra gears.The c160 box uses thinner gears though so is less suitable for high power than the c52/56 Quote
Phil Posted May 14, 2015 Posted May 14, 2015 (edited) Yeah the ae111 lsd is an internal lsd so you use all of your none lsd parts to fit it.And the levin 6 speed box doesnt have the 3 bolt holes in the front of the box for the mount but you could strip your 5 speed box and put the 6 speed internals into your casing then just bolt the 6 speed endcasing on to house the extra gears.The c160 box uses thinner gears though so is less suitable for high power than the c52/56 ah ha understood Thanks Phil Edited May 14, 2015 by Phil Quote
german4efte Posted May 14, 2015 Author Posted May 14, 2015 my problem is, the MR-S DIFF doesnt FIT ! to thick ! ! fitting it self is no problem, no magic. Where can i find OEM AE111 LSD?Quaife will be cool option, but VEEEEERRRRY expensive ! Helical LSD would be great, no service cost. only put in and readyKAAZ service is crazy, every 3500-5000miles new oil, KAAZ oil !..NO ! ! Quote
Phil Posted May 14, 2015 Posted May 14, 2015 my problem is, the MR-S DIFF doesnt FIT ! to thick ! ! fitting it self is no problem, no magic. Where can i find OEM AE111 LSD? Quaife will be cool option, but VEEEEERRRRY expensive ! Helical LSD would be great, no service cost. only put in and ready KAAZ service is crazy, every 3500-5000miles new oil, KAAZ oil !..NO ! ! is it bad i read all your posts in a german accent and laugh to myself? sorry if this post didnt help anyone. just had to confess. Phil Quote
german4efte Posted May 14, 2015 Author Posted May 14, 2015 hihi....no problem i know my english is not best onei live in germany and only learned school english (long time ago) but in gemrnay i never found help or parts for my 4efte project so i need help from all over the world. Especially finding parts is hard Quote
