mark1991 Posted May 5, 2015 Posted May 5, 2015 I have been having this problem for some time now, can someone tell me what might cause this?Plugs are black and a slightly smell of fuelNothing had been changed previously and no engine management light appearing!Nothing is coming to mind A list of stuff to check please Quote
mikey4410 Posted May 5, 2015 Posted May 5, 2015 what are the readings on afr at....cold startwarm idlewotcruise Quote
_shaun_ Posted May 5, 2015 Posted May 5, 2015 have you spoke to the mapper to see what they think? possible you have accidently knocked your fpr or something and uped the fuel pressure? other than that id think air temp sensor/ water sensor/ lamda/wideband could throw up issues that would cause this Quote
mikey4410 Posted May 5, 2015 Posted May 5, 2015 plus also my plugs are black around the inner outside piece as mine hits 11.00 afr on wot but all the rest of the time the afrs 15.00 and runs perfect .u cant base that ure running lean on a black plug that smells of fuel lol Quote
_shaun_ Posted May 5, 2015 Posted May 5, 2015 plus also my plugs are black around the inner outside piece as mine hits 11.00 afr on wot but all the rest of the time the afrs 15.00 and runs perfect .u cant base that ure running lean on a black plug that smells of fuel lolrunning rich* Quote
mikey4410 Posted May 5, 2015 Posted May 5, 2015 yeah I know I know but not to the detriment of the car and I do not have running issues whatsoever. so there mr shaun haha Quote
_shaun_ Posted May 5, 2015 Posted May 5, 2015 ha i wasnt commenting on your car.you said you cant base that your running lean based on the smell of fuel and black plugs. you have it the wrong way round rich is to much fuel lean not enough Quote
satyrs Posted May 5, 2015 Posted May 5, 2015 maybe there is a injector faulty. that doesnt close well. get the injectors out on the rail and let someone else turn the car over. see if the spray patern is the same of all 4. Quote
mark1991 Posted May 5, 2015 Author Posted May 5, 2015 Will be changing lambda and map sensor, I did see 5bar fuel pressure at 1.8bar! Quote
mikey4410 Posted May 5, 2015 Posted May 5, 2015 ohh I just got that shauny.haha. I boo-booed. pmsl Quote
mark1991 Posted May 10, 2015 Author Posted May 10, 2015 Injectors are fine, map sensor is good and lambda is brand new.... Stuck Quote
AdamB Posted May 10, 2015 Posted May 10, 2015 What ecu are you running? Can you not log sensor data? Quote
