HELP! Catch can half full with water
Hi guys, ive got a fresh forged engine in. Been running it for about 400 miles.
Every oil change I do theres always a bit of white mayo on the filler cap, so i thought this may be condensation so havent worried too much about it.
Ive checked the catch can today and its half full with clean water?
Also each oil change the oil hasnt been milky, bit black but thats all.
dont appear to be losing coolant but hard to tell.
Bit weird how theres just clean water in the catch can, couple of milky spolges but that it.
Any ideas?? Head was skimmed and fresh athena headgasket put on 400 miles ago
Hmmmm, well the mayo doesnt appear to have cleared up over time its not eccessive but after each journey if you let the car sit it leaves a film on the filler cap. I thought i should be seeing oil in the catch can not water! its clear but smells petrolly.
would the oil or coolant change colour if the headgasket was the issue?
Air and water lines fine on throttle body, think it would empty pretty fast into the bores if i had them on the wrong way.
I filled the rad and filler bottle up 450 miles ago and its lost about an inch but that could just be because it was all fresh in a fresh engine. Going to top up the coolant to the line then i can judge if its loosing any.
My catch can isnt massive. Id say around 1/4 litre of water was in it
