Depends if it's a wideband afr gauge. You can get cheap narrow band afr gauges that would work with the stock lambda but they just show lean/rich there's not really any point in having one it doesn't show enough info
  • 2 weeks later...
Is it possible to run an AFR gauge off the stock lambda sensor? Or would I need a wideband?
The only gauge that works right is the DEfi Af gauge old school...
Not really worth it like _shaun_ says.
Narrow band sensors read from 0-1v and widebands read from 0-5 giving a much bigger range for the reading.
Better of just getting a wideband kit like a Innovate or AEM and get a true reading
Cheers for the answers guys :) was idle curiosity really, I was toying with getting a pillar 2 gauge pod but only have the one gauge to go in (tacho) and what with it being an N/A I genuinely don't need any others. AFR was the only even slightly useful one I could think of.
Why would you not worry about afrs, its one of the most important. They are all important within their own right.
