wanting to up the power abit in n/a and i think the sr has 85hp standard? correct me if im wrong. and so wanted to swap the ecu's over, would an SR ecu swap straight over or does it need a loom adapter making??
just fit turbo ecu and loom sensors etc it works perfect on na engines and will have 7500rpm limiter
Wouldn't you get valve float if you raise the limiter without uprating the springs?
