as above has anyone a picture of where these plug into ive have the car apart trying to figure out where these plug into ive the little harness and controller box
ive looked in the footwell but the white plug look diiferent than my wiring
Same.......I have 2 white plugs on mine and what I'm guessing is an earth? Looked in the drivers footwell behind kick panel but a can't figure it out either lol, am I just being thick or what?
no Flynn im in same boat I can see the white plug they mean that's has to be disconnected
but its bigger than the plugs I have on my on my glow barrel light loom
I presume this is the plug that gets disconnected
the other three plugs that are there none of these fit either
heres my problem different plugs
Here's what I've got
48EB65E4-9FF6-4E32-9BAA-F48AF4F5A851_zps
73CF3E8D-18C8-4D48-BF5A-0CBB5BCF7F06_zps
F1B67906-ACAE-4033-9CCB-F327BF59AFF0_zps
You can't see it there but there is the little black box and an inline fuse.
And here's behind the drivers kick panel
0C4F8340-6FDE-4C40-AF0E-E7A599D8ACDB_zps
Was there a difference between 82's and 91's?
And did they both have these as an optional extra?
apparentley not as the ones ive seen for sale fit an ep82 and ep91's
both the gt and glanza had these as an optional extra
in this pic you can see its the same as mine but im missing some part of the loom
the part with the blue wire running through it I have the two plugs this has 3 of them all joined together
Edited by JDMfreak
I am literally at the point of putting my foot through the side of the fucking car......can't make my plugs match up with anything I've found. Plug and play?
Mines was plug and play just hard wire it mate ?? so was yours taken out of a Glanza/gt or maybe something else ae101 or something hence the reason they don't plug in anywhere ???
Was trying to avoid doing that but the mrs brother is a sparky, might have to give him an ask.
Was told it was out of a Glanza but I'm starting to think not :/
Flynn yours will plug and play see the white plug in this pic disconnect it
and plug the one end of the footwell/glowbarrel loom you just disconnected into one end and the other one into the other end
Ah, I spotted that one but as everyone was banging on about the kick plate and this ones above that behind the panel below the steering wheel? I was freakin out I might blow the electrics lol
How sure are you??
sure unplug them and see if they fit one another disconnect battery if you feel unsure the ones at the lower part are only a 6 pin plug
Mate you were spot on with that advice! Plucked up the courage to go for it and we have lights!
142E2A1F-B3FA-4B5C-BF7B-3E2BF126D74C_zps
Was speaking to another guy who seems to think they may have had different plugs on early models? And that there are MR2 variants kicking about with different connectors. Hopefully someone else maybe able to advise you properly?
bump
anyone able to tell me where I can hard wire them in looked through tutorial but 1 thread is missing images really wanna get these fitted
  • 1 year later...
