Erm it's completely standard glanza so all standard injectors and stuff it use tk have a decat but it kept fuel cutting so since then I have just kept the cat on it ' could it be to do with the fact I have a hole in my air filter ?
Checked the cat and all seems ok so not too sure what else it could be ' it failed on the 2nd fast idle test it was 0.61 on carbon monoxide or something anyone else suggest other reason it could be thanks ?
High CO means that you are running rich mixture. Common faults are lambda, cat, bad plugs/plug leads/distributor cap/rotor. Also the engine temp sensor might be the problem, but usually you got CEL then.
I'll check the lambda and cat again carnt see it been plugs there new and the new leads and distributor cap and rota is new as I had missfire early this year I will also check the engine temp sesnor thank you 😁
You can get CAT cleaners to help pass the MOT, might be worth a try. Did it one year on mine at a garage when it failed then passed.
lambdas are a servicable item on these cars, and also, give the car a good fast high rev drive before the test, as the cat will only work correctly at high temps
