Hi All,
Does anyone know where to get standard suspension top mounts from? (For my EP82 GT)
I've spoke to ID-Workz who can't get them and I've had no luck with ICP...
Found them advertised on a site called 'Burrows Toyota Parts', at £85 quid each, for the EP91, are they the same as the EP82?
Didn't realise they were that expensive! Thought I would be able to refresh the standard parts for fairly cheap.... Instead I might just wait for some second hand coilies.....
Cheers!
Dan
Ep82 and ep91 top mounts are different but they still fit. The ep82 ones just cause the car to sit a little higher at the front.
Find someone breaking a low spec car or someone who is upgrading one.
That is certainly a start! Thanks!
So the tops mounts are shared across the models? So a standard 1.3 (non GT/Glanza) top mount will do?
Edited by Sherb87
