building a wilwood kit at the moment.
let me know if your interested
not sure how much ksports are these days?
these might not work out much cheaper!
Phil
888£ roughly for the 4pot 286mm kit
575£ Wilwoods are 4pot 275mm
Plus pads
Just for comparison
Phil
Edited by Phil
wilwoods are great value for money! I got a 4pot setup with disks and pads and adapters(for a civic)for £500 from america. Not sure what sort of modification it would need for a starlet
Calipers are around £100 each so could spec your own kit too. Most companies seem to charge silly amounts for a logo and the fact they bolt straight on. Bit of research and machining you'll save yourself a few bob.
Edited by Ollieh17
How did you get on with the kit for the Charade?
Went to get it all machined but guy wanted a few days to do it and had retro rides at the weekend. Bolted the car all back up and fixed the standard brakes. Deciding wether to just stick some new pads and disks on or fit the wilwoods,stock brakes are pretty good tbf
Dude you have taken the plunge and got the wilwoods get them fitted I'm sure you won't regret it :D
James
