Faiyaz.123 Posted September 3, 2015 Share Posted September 3, 2015 As the topic .what sealant can i use for the an fitting to fuel rail .I have a zisco fuel rail with fpr .the connection at the fpr is fine but to the fuel rail is leaking. Quote Link to post Share on other sites
Ollieh17 Posted September 3, 2015 Share Posted September 3, 2015 Ptfe tape Quote Link to post Share on other sites
5e colin Posted September 3, 2015 Share Posted September 3, 2015 non attal there designed to be tightend with no sealer Quote Link to post Share on other sites
Ep82gi Posted September 3, 2015 Share Posted September 3, 2015 non attal there designed to be tightend with no sealer I'll second that. Quote Link to post Share on other sites
Johnboy GT Posted September 3, 2015 Share Posted September 3, 2015 The cone on the fitting is where it seals. Check that there isn't a flat spot on the cone mate.John Quote Link to post Share on other sites
Starlet__SR Posted September 3, 2015 Share Posted September 3, 2015 As above, its a taper fitting. Quote Link to post Share on other sites
Faiyaz.123 Posted September 7, 2015 Author Share Posted September 7, 2015 So that means new connectors ? Quote Link to post Share on other sites
funny onion Posted September 7, 2015 Share Posted September 7, 2015 As above- shouldn't need sealant, but you could try some pfte tape or liqid ptfe Quote Link to post Share on other sites
akyakapotter Posted September 7, 2015 Share Posted September 7, 2015 i just tightned mine up worked for me Quote Link to post Share on other sites
Flaminsam Posted September 7, 2015 Share Posted September 7, 2015 Be aware that the an fittings are a 37 degree taper. If you get cheap fittings they are at a 45 degree taper and will not seal. Quote Link to post Share on other sites
Faiyaz.123 Posted September 12, 2015 Author Share Posted September 12, 2015 New line and new fitting problem sorted !! Thanks to my buddy. Last thing we wants is a fuel leak while on dyno!!.Thanks to everyone for the input . Quote Link to post Share on other sites
