cory42 Posted September 6, 2015 Posted September 6, 2015 hi everyone. if you run 1 bar of boost on a stock ct9 will you need a different exhaust manifold? thank you. Quote
patman Posted September 6, 2015 Posted September 6, 2015 Unless you port the standard manifold then yes of course Quote
cory42 Posted September 6, 2015 Author Posted September 6, 2015 ok thank you patman, ive only just bought a glanza 2 days ago which is running 1 bar of boost on the stock manifold and its blow the turbo gasket. which manifold would you recommend? Quote
patman Posted September 6, 2015 Posted September 6, 2015 (edited) Ok first things first mate turn the boost down, and find out if it has a fuel cut defender on it, I'm doubting it has a aftermarket ecu on it as still standard manifold, have a good look around this forum, as the way your car sounds at the moment 1bar of boost and completely standard I would advise not to boost it at all, what mods have been done to the car etc, Edited September 6, 2015 by patman Quote
cory42 Posted September 6, 2015 Author Posted September 6, 2015 it has a fuel cut defender, and front mount intercooler but that's as much as i know. i think its still on the standard ecu. what would happen if i didnt turn the boost down? thank you Quote
daniel_g Posted September 6, 2015 Posted September 6, 2015 it has a fuel cut defender, and front mount intercooler but that's as much as i know. i think its still on the standard ecu. what would happen if i didnt turn the boost down? thank youThis. Quote
cory42 Posted September 6, 2015 Author Posted September 6, 2015 ah makes sense. what boost should i run ? Quote
Whitenoize Posted September 6, 2015 Posted September 6, 2015 (edited) This. that's 2.8 bar on a ct9 isn' it?? t I've seen that before ? Edited September 6, 2015 by Whitenoize Quote
patman Posted September 6, 2015 Posted September 6, 2015 First thing I would do mate for now is get yourself a standard actuator and put on ASAP then get that fcd off ASAP then get a good boost gauge fitted then go from there Quote
cory42 Posted September 6, 2015 Author Posted September 6, 2015 ok will get that done asap, thanks for the help much appreciated. what part would i need to safely run 1 bar? Quote
patman Posted September 6, 2015 Posted September 6, 2015 A lot of money mate would be a good start to be fair, that's running a safe 1 bar, at the moment your well into the danger zone, and who ever sold you the car must of known himself the cars on the verge of blowing up, just do what I said above mate then go from there Quote
cory42 Posted September 7, 2015 Author Posted September 7, 2015 ok thanks patman will get it sort asap Quote
StuDoc 72 Posted September 7, 2015 Posted September 7, 2015 Dont fit a standard actuator. Just lengthen the rod on your adjustable one. ( turns down the boost ) Remove the FCD. Get a boost gauge and run 0.7 bar on your actuator. Quote
patman Posted September 7, 2015 Posted September 7, 2015 I said for him to get a standard one as then he can't go wrong his very new to this and has to learn like we all dos once, as just lengthening the rod on the adjustable one will probably turn into how long,then he might do it too long and get no boost etc, so just wacking a standard one on for now would be much easier and you can pick them up on here for like a fiver Quote
cory42 Posted September 7, 2015 Author Posted September 7, 2015 hi guys, i had a look at the fcd earlier and for a black back that has denso 1 on it. is this standard to the glanzas? thank you Quote
StuDoc 72 Posted September 8, 2015 Posted September 8, 2015 What? I don't get it. FCD's will most likely be HKS or JAM. Quote
cory42 Posted September 8, 2015 Author Posted September 8, 2015 it has a hks fcd, when i was having a look at how it is wired in i found one of these http://www.upjpn.jp/yahoo/goods_photo/911549/6381.html is this standard on a glanza? Quote
Whitenoize Posted September 8, 2015 Posted September 8, 2015 it has a hks fcd, when i was having a look at how it is wired in i found one of these http://www.upjpn.jp/yahoo/goods_photo/911549/6381.html is this standard on a glanza? wtf is that never seen one of those before Quote
cory42 Posted September 8, 2015 Author Posted September 8, 2015 i have no idea cant find any info on them Quote
daniel_g Posted September 8, 2015 Posted September 8, 2015 Yeah pretty sure its something to do with AC or climate control or some shit. Its attached to the dash loom up near the glovebox on a GT, duno about a V. Quote
patman Posted September 8, 2015 Posted September 8, 2015 Was setting was the fcd on cory by the way Quote
