Vturbo Posted October 22, 2015 Posted October 22, 2015 (edited) Right so does anyone know what is the right bracket for the lsd box? The one on the right got sent with th lsd box but I'm not sure if it's correct....Cheers! Edited October 22, 2015 by Vturbo Quote
jayc-glanza17 Posted October 22, 2015 Posted October 22, 2015 The left is definately a non oem lsd mount Quote
akyakapotter Posted October 22, 2015 Posted October 22, 2015 one on the right id say after looking at google images Quote
Vturbo Posted October 22, 2015 Author Posted October 22, 2015 (edited) cheers guys just seems lie the bushing don't fit inside! The right one doesn't seem wide enough or am I missing something Edited October 22, 2015 by Vturbo Quote
karl. Posted October 22, 2015 Posted October 22, 2015 Has anyone got one of the lsd ones spare? I need one for my box as well. Thanks Quote
daniel_g Posted October 22, 2015 Posted October 22, 2015 (edited) The mount on the car is also different.X2 have you got the alloy underside mount too?The two are very different. Edited October 22, 2015 by daniel_g Quote
Vturbo Posted October 22, 2015 Author Posted October 22, 2015 Yes guys I have the alloy underside mount. All sorted now anyway! cheers Quote
Essexglanza Posted October 22, 2015 Posted October 22, 2015 I would say neither are correct, the left one is the right shape and height but the fitting on the left side should be flush with the mount, I ordered the item new the other week after struggling to find one 2nd hand and the mount on the car should be alloy not steel, bush is different too. I've had a headache but now sortedHaha, just read you're post aboveMy bad !!! Quote
Vturbo Posted October 22, 2015 Author Posted October 22, 2015 I would say neither are correct, the left one is the right shape and height but the fitting on the left side should be flush with the mount, I ordered the item new the other week after struggling to find one 2nd hand and the mount on the car should be alloy not steel, bush is different too. I've had a headache but now sortedHaha, just read you're post aboveMy bad !!!I think you're right to be honest... After more investigation none of them look right.. Quote
Vturbo Posted October 23, 2015 Author Posted October 23, 2015 Right so I have been to Toyota and ordered a bracket and they told me it will arrive in the 1st of January....is there anyway I can adapt a standard bracket as a temporary fix???? Quote
