StarletRick Posted February 27, 2008 Posted February 27, 2008 Right, I have been looking into replacing the rubber bushes that the shifter assembly uses to fix itself to the floorpan of the car. i have found an engineering place that will make them up for a semi decent price, but the deal is i have to buy lots.. so here comes the group buy. for those that dont know what they are... they are little steel bushes that replace the rubber ones that come stock. if youve ever taken your lower console off and driven the car, youll notice that the shifter housing moves about a bit as you shift. this is intended, the original OEM bushes are meant to isolate the lever from vibration. the downside is you lose a bit of feel with the gearbox as some of your shifting movement is moving the housing, and not the shifter cables. these bushes stop that indefinatly. all movement is transfered directly to the gearbox and should give a much firmer "feel" with the gear changes. coupled with a short shifter, they are the winz, but will work noticably well on a stock setup.ill be getting these made up in steel so they will be very strong, and they will also be Zinc coated to stop any degradation to the parts. given enough interest, ill probalby be able to get them made up for 10-12 quid a set. its a cheap mod that you can feel the difference of, just what everyone likes! theyll also fit anything, EP82/EP91, paseo, cynos, levin etc. only thing they wont fit is the 6 speed. names down now please... 1. Rick2.3.etc Quote
Mikey Jay Posted February 27, 2008 Posted February 27, 2008 Go on then1.Rick2. Mikey Jay (AE111 Levin - do I need to find out anything for you regarding dimensions or whatnot?) Quote
StarletRick Posted February 27, 2008 Author Posted February 27, 2008 nope, theyll be the same mate. Quote
Nanglebadger Posted February 27, 2008 Posted February 27, 2008 1. Rick2. Mikey Jay3. Phil (nanglebadger)For like £12 or so u cant really go far wrong! its all about the preparation for the conversion!Phil. Quote
Mikey Jay Posted February 27, 2008 Posted February 27, 2008 Funky stuff.by the way, want me to post this up on the levin club? Quote
riko666 Posted February 27, 2008 Posted February 27, 2008 could you make up bushes for the shift linkages too pweez?? Cpies if you can ;) Quote
Mikey Jay Posted February 27, 2008 Posted February 27, 2008 could you make up bushes for the shift linkages too pweez?? Cpies if you can ;)What be they, what they do? Quote
StarletRick Posted February 27, 2008 Author Posted February 27, 2008 i probably could tbh... ill see. thatll be alother group buy though mate Quote
Glanza_Ragger Posted February 27, 2008 Posted February 27, 2008 Nice price bud, ive just got some made you bastard...Cost me £30 ;) Good luck getting everybodys names down Rick Craig. Quote
59bhp Posted February 27, 2008 Posted February 27, 2008 1. Rick2. Mikey Jay3. Phil (nanglebadger)4. 59bhp Quote
StarletRick Posted February 27, 2008 Author Posted February 27, 2008 Riko will have some too, blates.1. Rick2. Mikey Jay3. Phil (nanglebadger)4. 59bhp 5. Silo Quote
riko666 Posted February 27, 2008 Posted February 27, 2008 unfortunately I got some already with the TuRD shifter honeybuns, sowwie ;) Quote
StarletRick Posted February 27, 2008 Author Posted February 27, 2008 fuck you, youre buying some anyway. Quote
StarletRick Posted February 27, 2008 Author Posted February 27, 2008 this is picking up some steam. Silo, post this on the seo club please bub.loves you xx Quote
ecksjay Posted February 27, 2008 Posted February 27, 2008 fuck you enrico.just wanted to join in with that ^; Quote
4EFTE Sol Posted February 27, 2008 Posted February 27, 2008 I'll have some por favorcould someone write up a fitting guide? Quote
Bluebear Posted February 27, 2008 Posted February 27, 2008 ^^^ Seconded. If its not too complicated to do, then count me in. Quote
Mikey Jay Posted February 27, 2008 Posted February 27, 2008 Yeah, fitting guide would be mucho nice Quote
Nanglebadger Posted February 27, 2008 Posted February 27, 2008 mates, its EASY to fit! like... 4 screws in the consol, lift it up, easy!Phil. Quote
ecksjay Posted February 27, 2008 Posted February 27, 2008 you take the surround off, and unbolt the shifter. its that easy. Quote
4EFTE Sol Posted February 27, 2008 Posted February 27, 2008 Gimme gimme then =]Rick let us know when you've got them Quote
Bluebear Posted February 27, 2008 Posted February 27, 2008 Took the liberty of adding your name down as well, 4EFTE Sol. Hope you don't mind.1. Rick2. Mikey Jay3. Phil (nanglebadger)4. 59bhp5. Silo6. Streetracer_starlet7. 4EFTE Sol8. Nick (Bluebear) Quote
