Hi lads Glanza started acting up and not boosting to normal psi its only boosting to .4 and it sounds like there's a leak in the engine bay somewhere there's air rushing out of something and I can't seem to figure out where anyone have experience with this and know how to solve? Thanks lads any help appreciated :)
If you smoke a ecig take the biggest dirtiest toke you can and blow it into the intake and block the air filter and the smoke will come out the leak
Now thats an idea!!
Silly question do you mean take air filter off blow into that pipe, (I have a grill location one) then block that pipe off, may give this a go just to see any leaks
on a cold ish moter spray sopy water al over the hoses and connections intake manifold and rev the car up blipping the throttle to lets sat 4000rpm
if you have an air leak it will blow big foamy bubbles there
If you can get a good seal then that's fine but if not down the dump valve pipe will do or something along those lines. But obviously the smoke will come out the filter if it's open
Genius!!!
Edited by pdg190
Thanks Alex mate that sounds a better place, it's definitely worth doing anyway for peace of mind
Nicks e-cig is the reason it's so bloody foggy every so often when he's in the car I just get a plume of fog drift from the back and block the sun it's ruthless
I'm the reason dinosaurs went extinct
