dan106 Posted November 5, 2015 Posted November 5, 2015 So i bought a cheap set of wheels, but when i put two on the front they make the same rumble as a gone wheel bearing, but its gone now ive put shit steels back on. Havent had a chance to look in to it that much, but just wondering if anyone has had it? Quote
Sefton-EP91 Posted November 5, 2015 Posted November 5, 2015 Are the tyres the same? I would say it's tyres rather than the wheels! Are there any massive differences between the wheels? Quote
dan106 Posted November 5, 2015 Author Posted November 5, 2015 I was thinking tyres as yes they were two different ones, I'll try the two with matching baldys tomorrow aha, Quote
StuDoc 72 Posted November 6, 2015 Posted November 6, 2015 Did the wheels sit flush on the hub? Is the centre bore the correct size? Did you use alloy wheel nuts or steel wheel nuts? Are the stud holes worn? Sounds to me like the wheels weren't on right. Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 Centre bore is way off to be fair, but I've never had spigot rings and I've never had this noise beforeWheels did look like they sat flush, but thinking about it the face of the back of the wheels was well corrodedSteel nuts, hole looks fine, bolts sat nice in the wheelIt was raining and dark when I fitted them so I didn't look into it greatly tbh Quote
Ep82gi Posted November 6, 2015 Posted November 6, 2015 (edited) I get the same thing all the time it doesn't do it at about 60-70mph but anything other than that and it dose you can feel it in both footwells if you grip the steering wheel really tight. It's caused by the fact I have no spigot rings for my wheels n the centre is well off. Edited November 6, 2015 by Ep82gi Quote
StuDoc 72 Posted November 6, 2015 Posted November 6, 2015 Fit spigot rings. Clean the alloys mating face. Use alloy wheel nuts as the are tapered and steel wheel nuts aren't. Get the wheels balanced and look for visible buckling. Once you've done all of that they will be fine as long as they aren't buckled. Then if you still have any vibration your tyres are goosed. Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 Steel wheel nuts are tapered aswell, if I weren't using tapered wheel nuts they'd do more than just make a funny noise lol!I'm thinking it's the tyres, I'll try the other two after work and go from there Quote
StuDoc 72 Posted November 6, 2015 Posted November 6, 2015 Not all steel wheel nuts are most of them are rounded. Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 I'm using tpi extended ones, had them on 3 cars with no spigot rings and never had a problem, gotta be the corrosion on the wheel or the tyres then Quote
StuDoc 72 Posted November 6, 2015 Posted November 6, 2015 Ahh so they are alloy wheel nuts anyway. If you get them sitting flush and sure they are tight then its either the tyres or buckled wheels. Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 Na they are steel ones still, I'll never use alloy ones again after the d1 specs I had on my n/aThey will be tight I always use a torque wrench on wheels Quote
morgey Posted November 6, 2015 Posted November 6, 2015 I think he means they are designed for alloys not theyre made of alloy 😉 Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 Now see that makes more sense aha! Using these nuts(You can see why I want to change these)These wheels (front ones) Quote
StuDoc 72 Posted November 6, 2015 Posted November 6, 2015 I think he means they are designed for alloys not theyre made of alloy Yes this lol. And yes those are alloy wheel nuts they would be fine. Quote
JDMfreak Posted November 6, 2015 Posted November 6, 2015 tyres out of shape by any chance inspect tyres see if theres any parts of them buldging or deformed seen tyres make odd noises because of mounting kerbs and breaking the small plys inside of them making them deform and rumble Quote
H_D Posted November 6, 2015 Posted November 6, 2015 Had the same problem turned out they just needed balancing 1 had to much weight on ot Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 Yeah they're cheap wheels pretty damn buckled, so I stuck them on the back and put my Rotas on the front, seems ok so far Quote
dan106 Posted November 6, 2015 Author Posted November 6, 2015 Yeah i know, should see the inside lip, on one it didnt run two at any point, the balancer said it needed 60 and a 105 hahaha, theyre cheap shit no name wheels so its no surprise, cant complain for 50 quid with two useable tyres Quote
