Anyone have a fake sard are they ok to use or know the difference between real ones and fakes?? What advantages are there of running fpr on ct9 set up just to up the pressure slightly to keep up with higher boost levels? What's needed to install? Any help would be great Thanks
As above you wont need to change the fpr for a ct9 setup its good enough unless your going td04 running over a bar you would then need one
no you wont
It's fine as mentioned for most set ups, but having an adjustable reg gives more scope for adjustment when in the mapping phase. It's not a necessity though.
