paddy Posted January 26, 2016 Share Posted January 26, 2016 I get this rattling noise coming from my clutch / gearbox I've come across it on a few cars, it's on tick over and goes away when u put your foot on the clutch pedal. Is this the clutch of is it from the gearbox? I'm pretty sure my clutch is on the way out but if there's a problem with the gearbox I will get that done to, I've been told lay shaft bearing? Quote Link to post Share on other sites
5T4R7ET N/A Posted January 26, 2016 Share Posted January 26, 2016 Could be shaft or release bearing in my opinion Quote Link to post Share on other sites
Mk3 silver gt Posted January 26, 2016 Share Posted January 26, 2016 Probs the clutch bearing mate because mine does it and was brand new with the 6 put I got but because it's not a genuine 1 it rattles so I've got to replace mine with a genuine 1 Quote Link to post Share on other sites
DRiiFTiE Posted January 27, 2016 Share Posted January 27, 2016 Thrust Bearing Quote Link to post Share on other sites
paddy Posted January 27, 2016 Author Share Posted January 27, 2016 I've been told lay shaft bearing, but could it be release bearing? Will be very happy if just a full clutch kit would solve it but think it's internal. Anyone done a lay shaft bearing? Quote Link to post Share on other sites
H_D Posted January 27, 2016 Share Posted January 27, 2016 Its the release bearing mate. quite common on these cars Quote Link to post Share on other sites
akyakapotter Posted January 27, 2016 Share Posted January 27, 2016 dose it do it when driving ? Quote Link to post Share on other sites
5T4R7ET N/A Posted January 27, 2016 Share Posted January 27, 2016 You will need to remove the gearbox for release bearing or the input shaft. So you will be able to see if there is any play in the input shaft and replace the release bearing whilst the gearbox is off Quote Link to post Share on other sites
paddy Posted January 28, 2016 Author Share Posted January 28, 2016 Be nice if its the release bearing but I'm thinking it's the shaft. It doesn't do it while driving. On tick over u can see the selector fork shaking about a little. It didn't do it with my old gearbox, I fitted a gt box and a used organic clutch plate, and it's rattled lots since fitted, I don't think it's the release bearing as it's the same one I used before as I knew it was good Quote Link to post Share on other sites
H_D Posted January 28, 2016 Share Posted January 28, 2016 sounds like it is release bearing if the noise is not present whilst driving - once a release bearing is removed they should be replaced hence why its now making a noise. Lots of members on here had this issue when re-using the release bearing Quote Link to post Share on other sites
akyakapotter Posted January 28, 2016 Share Posted January 28, 2016 (edited) when my bearing inside the box had gone it done it when driving the car. Edited January 28, 2016 by akyakapotter Quote Link to post Share on other sites
paddy Posted March 18, 2016 Author Share Posted March 18, 2016 Can anyone else shed any light on this? Gonna replace the input shaft front bearing (the one around the shaft with the splines) and put in a genuine release bearing all along with a new paddle clutch kit, Hopefully this will sort it, has anyone else cured this rattling noise? I've come across is on 7 different starlet boxes sure other people have to Quote Link to post Share on other sites
StuDoc 72 Posted March 18, 2016 Share Posted March 18, 2016 Its your flux capacitor Quote Link to post Share on other sites
H_D Posted March 18, 2016 Share Posted March 18, 2016 On 3/18/2016 at 2:18 PM, StuDoc 72 said: Its your flux capacitor il second that Quote Link to post Share on other sites
epcashin Posted March 18, 2016 Share Posted March 18, 2016 sounds like your headgasket mate :/ Quote Link to post Share on other sites
Bug679 Posted March 18, 2016 Share Posted March 18, 2016 It's your release bearing mate if it was any other bearing you'd hear it when your driving to Quote Link to post Share on other sites
Matt12 Posted March 25, 2016 Share Posted March 25, 2016 It's the release bearing just done mine today and replaced it noise has now stopped. Quote Link to post Share on other sites
Robbiemclough Posted April 5, 2016 Share Posted April 5, 2016 I have an oem lsd box that do this as well! brand new clutch kit and koyo bearing had similar noise in another box and am not sure like yourself lol but I have a thought that the clutch fork on the box could be bent a little bit and causing the bearing noise as it could keep it correctly in place , the box drives well other wise except for little 3rd crunch at speed lol as I said just a thought lol Quote Link to post Share on other sites
