C56 is a common conversion, shorter final drive and a few different gear ratios. Same design internally. Just swap off the 4age bellhousing and drill the passenger side mounts into the casing and your good to go. Good and strong.
C160 also fit but are a weaker box. Probably fine for most setups though.
Larger E series boxes don't physically fit without massaging the chassis
Edited by Stu
Do 2nd gear crunch?
No everything is fine no crunches, the shorter ratios give it more of a punch in the lower gears than a starlet box. only thing you have to modify is the shifter as reverse is next to first on this box. just need to notch some plastic from the shifter housing. gear cables, mounts etc are a straight swap
What's the strongest box availible ?
C52?
Phil
Stock c52 and c56 are very similar other than the c56 is a shorter ratio box. Both are pretty strong.
C150 (EP71 N/A), C152 (EP71 Turbo), C160 etc are all lighter weight gearboxes
Will a C64 Gearbox fit? Does it hold enough power?
E58 would be perfect!!!
Not sure what all would need done to make a c64 fit but Juba do an uprated 3rd/4th gear for them so def a swap I'd be interested in.
Come in Toyota engines lotus etc
Phil
What's the craic with an e85?
Phil
E58 can hold tons of Newtonmeter Torgue =D
bit heavier.. but i think u cant break it with a starlet
does somebody now how Strong the C64 gears are compared to C52?
Edited by Bananajoe888
E series boxes are physically much larger, you need to do some "manipulation" to make them fit. Plus they dont come with an e series bellhousing
yea thats shit.... cant someone make a custom bell housing?
or where i can get a e58??
No way of getting e85 gearset into our casing/bell housing?
Phil
Phil
NO sry, no chance to do that
i think i try C64 swap in my starlet. Think this will hold better than C52..
300whp is much..
300whp is much..
Fire us as many details as u can
I wondered before if a c64 gearset would fit in one of the 6speed gearboxes that people use from a g6 corrolla? Then mate it to the c52/56 bellhousing?
Pretty sure the c64 casing isn't suitable in terms of selector position and starter position etc being from a rear engines rwd lotus
What gearbox comes in a fwd tsport 2zz?
Phil
Same box, the corolla and celica use C64 and 63 i think. The celica has closer ratios in 2nd and 3rd i believe.
The boxes can be modified to it front or rear engined like the old c52 in the old aw11 mr2
Guys.. had a interesting talk with an Motorsport guy from Germany... he told me a way to use C64 (Corolla T-sport gearbox) nearly PnP on starlet.
he said "you only have to combine the right parts =P
Its just a case of using the right housings so that the gearbox bolts to a e series engine.
EDIT:
Its interesting looking a the ratio comparisons between the C56 and the C64.
C56
A 5-Speed Manual Transmission for FWD and mid-engine cars. Compared to the C50/52, it features close-ratio 3rd-to-4th gearing.
1st 2nd 3rd 4th 5th Reverse Final
3.166 1.904 1.392 1.031 0.815 3.250 4.312
C64
1st 2nd 3rd 4th 5th 6th Reverse Final
3.166 2.050 1.481 1.166 0.916 0.815 3.250 4.529
Really short final drive, would be doing a fair few revs at 100kph!
Edited by Stu
