morgey Posted October 6, 2017 Posted October 6, 2017 Do you know what you used previously? You should be able to upload direct to the forum now, theres an option at the bottom of the reply box. Failing that, imgur or tinypic can be used to host then just copy the img code in or try the tapatalk app for forum access and direct uploads. Quote
JDM_MARK Posted October 6, 2017 Author Posted October 6, 2017 I used photobucket previosly and i try adding an image on the click to choose files but its saying only allowed up to 501kb Quote
JDM_MARK Posted October 13, 2017 Author Posted October 13, 2017 (edited) Hi everyone haven't uploaded anything for a while so there is plenty of photos to share of the progress of the old starlet. Some of you already know that I am doing an itb build with tt600 throttle bodies so there is also plenty of progress on that to share. I will upload photos as soon as I have figured out what to use to upload them. Â Â Â Â Edited October 13, 2017 by JDM_MARK Quote
JDM_MARK Posted October 15, 2017 Author Posted October 15, 2017 (edited) I also bought a second starlet it is a 4 door and it has seen better days. I used this for the bonnet and wing and everything else if for spares. And then there's these. Â Edited October 15, 2017 by JDM_MARK Quote
maddox710 Posted October 16, 2017 Posted October 16, 2017 Good to see someone stepping into the itbs route. Love to see how it's turns out, keep up the good work Quote
JDM_MARK Posted October 16, 2017 Author Posted October 16, 2017 (edited) 6 hours ago, maddox710 said: Good to see someone stepping into the itbs route. Love to see how it's turns out, keep up the good work  cheers Edited October 16, 2017 by JDM_MARK Quote
westie Posted October 17, 2017 Posted October 17, 2017 Hi Mark, I'm after a rear bumper for my silver na, would you be interested in selling the one from your spares car? Â Quote
JDM_MARK Posted October 21, 2017 Author Posted October 21, 2017 On 17/10/2017, 18:10:17, westie said: Hi Mark, I'm after a rear bumper for my silver na, would you be interested in selling the one from your spares car?  Sorry mate going to keep all the parts that i can use for my car Quote
JDM_MARK Posted October 22, 2017 Author Posted October 22, 2017 Onto the itb progress The first thing that I wanted to sort out was how I was going to fit the tps to the throttle bodies. I know a few of you have just made an adapter plate and it fits but I don't know why my tps doesn't go on the itb so I was going to look for a different tps but then I thought I will file the Shaft on the itb a bit thinner so it goes into the tps and then just make a simple adapter plate for the different hole patterns. Once I sorted the's two things I put it on bolted it on and found the start of the tps travel.    Quote
JDM_MARK Posted October 22, 2017 Author Posted October 22, 2017 (edited) The next thing I did was put the itb's on the car using a chopped manifold and rubber hoses. I also got the cable to fit in the standard bracket so at that time I didn't have to make a long bracket for all the cable instead I tightened the cable to the bracket and pushed the extra cable through to the foot pedal. I then made a stop to put on the cable so when I push my foot down it pushes on the stop pulling on the cable. It is just a a piece of aluminium that has got a grub screw in the top and then a bolt on the side pulling the split bush together keeping the cable in. I then plugged everything up and tried to start it and it wasn't starting after standing there scratching my head for a considerable amount of time I noticed a ground wasn't connected so bolted that to the engine and tried again and it fired right up. Did have to adjust the idle but after that it started and idled fine and it sounded mean. This setup was only temporary just to get it started and prove it worked then I began building a manifold from scratch. But before that there was one thing bugging me which was when you rev it the throttle pedal is either on or off one touch and it revs right up. I asked others and they said they got used to it but I thought I'd try a way of sorting it out by making my own throttle cable pulley for the itb's out of aluminium. Edited October 22, 2017 by JDM_MARK Quote
JDM_MARK Posted October 23, 2017 Author Posted October 23, 2017 I do have a few videos I will first have to upload them to youtube Quote
*Pete* Posted October 24, 2017 Posted October 24, 2017 OOOOO! Like the sound of that! Can't wait to hear more! Quote
JDM_MARK Posted October 27, 2017 Author Posted October 27, 2017 (edited) While I've got a bit of time I thought I'd share a bit more of itb progress. This is where it starts to get a bit more interesting.I left the last upload with the problem of the throttle pedal being too sensitive. I did end up making a pulley and the idea behind this was to try and make the radius of the cable end hole to the centre of the pulley larger .This way it requires more pedal travel to full open throttle instead of the tiny tt600 pulley. Anyway enough talking I'll let the pictures do the talking. First i turned this up Then I cut it and filed it  Edited October 27, 2017 by JDM_MARK Quote
JDM_MARK Posted October 27, 2017 Author Posted October 27, 2017 Then I have built a manifold from stainless bends and a mild steel flange. Once happy with the length and fitment of the runners I gave it a good weld up. Â Â Quote
JDM_MARK Posted October 28, 2017 Author Posted October 28, 2017 18 hours ago, Gainzy said:  Nice work buddy Thanks mate Quote
JDM_MARK Posted November 11, 2017 Author Posted November 11, 2017 (edited) Hi all few updates to share on my progress with the thottest bodies. Well I hAve got round to fitting them on my car and had them on for 1 or 2 weeks now and I have had to take them back off as the fuel consumption is just terrible. Don't worry I am not giving up. I have got a wideband that I am going to fit and I am going to need some sort of management. Any way here is where I am now and I included a few machining shots. Thought It would be different.     I drilled and tapped holes in them for grub screws to lock them on the bodies. I also installed the fpr and made some p clips for the fuel line going across to give it a clean and tidy look. Whilst the throttle bodies are off I'm going to build a stainless exhaust manifold and then a exhaust all the way back but I'm not sure on what size to go for any ideas. plus any opinions on the build so far would be great. Got a few more vids 2 Edited November 11, 2017 by JDM_MARK Quote
maddox710 Posted November 12, 2017 Posted November 12, 2017 This is so awesome, lovin your engineering skills Quote
JDM_MARK Posted November 12, 2017 Author Posted November 12, 2017 Cheers they have definately come in handy with this project Quote
