ChristopherEP70 Posted March 1, 2016 Posted March 1, 2016 How would I go able changing the mileage ? I'm changing the clocks in my glanza so I want the correct mileage on the car Quote
5e colin Posted March 1, 2016 Posted March 1, 2016 unbolting the original clock and fitting it to the new 1 Quote
ChristopherEP70 Posted March 1, 2016 Author Posted March 1, 2016 Was thinking that but would I have to take the needle off Quote
EP70-PT Posted March 2, 2016 Posted March 2, 2016 Yes you have to take the needle off, it's so easy mate Quote
ChristopherEP70 Posted March 2, 2016 Author Posted March 2, 2016 Aren't the needles tensioned ? I had that problem with clocks before they weren't reading right after the needles were removed Quote
EP70-PT Posted March 2, 2016 Posted March 2, 2016 Nope, just pull them off gently, check my buid thread, you'll se how I did it Quote
SKINY Posted March 2, 2016 Posted March 2, 2016 Aren't the needles tensioned ? I had that problem with clocks before they weren't reading right after the needles were removedFit them back in without the plastic screen and then calibrate it using your sat-nav Quote
MARC MOSS Posted March 3, 2016 Posted March 3, 2016 What you should do is pull the needle anti clockwise over the zero stop pin and then mark where it sits without the tension first then you refit the needle in the same place when you put it back together Quote
hookie663 Posted March 3, 2016 Posted March 3, 2016 Best way to getneedle off is use a fork presses it off perfect Quote
5T4R7ET N/A Posted March 4, 2016 Posted March 4, 2016 You can use your finger or something small enough and press down on the numbers whilst scrolling down. Very easy Quote
