Simon Posted December 30, 2012 Posted December 30, 2012 (edited) After a lot of thought I’ve decided that I can’t justify spending the money I would need to get my Glanza to where I would be happy with it. So I’ve decided to break…This car was built from many of the parts from TMD’s sprint car as Dave is no longer with us I can’t get him to confirm the spec of the engine but as most of you know me I’m happy for any inspection within reason. I will also speak to Rob Barnard in the new yeah to see what he can confirm as he built the engine. The car made 317hp on 95 octane fuel in a rushed mapping session at Austec racing this was at 1.4bar of boost.Please read firstI’m near Sleaford LincolnshireRegards Payment and shipping collection and cash is king I will do some deals for multiple parts brought but I’m not in a rush to sell so no silly offers.I will post most items except large heavy items but you can always try me I travel about with work a bit mainly south east but we do have an office over St Helens that I get to some times.All items will be sent tracked/recordedPayments by paypal you must add the fee of 4%I have to work too it might take me a week or so to get something sent I do not do this full time so please bear this in mind.Sard radiator very rare fully width alloy rad.£120ZEP spherical shifter bearings fitted to cables£20Advan RCII 16" alloy wheels in white recently power coated these are 7J 4x114.3 so come with Project Kics 15mm PCD adaptors they have toyo 195/45/16 tyres. Front have 5mm, rears have 8mm. These are ET45 without the spacers ET30 with. They come with rays valves and wheel nuts.£500JDM Pioneer 10cm lightweight speakers 100w max 30w rms£20Earthing kit with gold battery terminals + & -£30 Rear parcel shelf with Addzest JDM speakers the name in these lights up if wanted give a good sound too.£50Rally Tech 15mm think anodized blue rear towing eye nearly new.£35 Rear axle groved discs, Cables and ABS sensors£80 DEI Universal Turbo Insulation Kit brand new neber used.This turbo kit is designed to fit all turbos from the sport compact turbos to the large over the road trucks. Designed to reduce turbo lag and reduce under hood temperatures, the Turbo Insulation Kit adds additional horsepower while protecting costly components from unwanted heat. The kit comes complete with all the materials necessary for a clean, professional looking installation.Designed to reduce turbo lag and under hood temperatures Universal application to fit all turbos Greatly reduces underhood temperatures Easy to install for professional lookKit Includes1 x 12" x 36" piece of heat screen2 x 14" Stainless Steel locking ties2 x 20" Stainless Steel locking ties1 x 2" x 25 piece of exhaust wrap1 x 6" x 36" piece of exhaust wrapInstallation Instructions£50 Momo Hub£20Wind deflectors pair£75Body work it’s all genuine NO FAKES Full Varis kitSide skirts in silver need paint £150 If this doesn’t sell I will consider splitting I have someone for the front bumper and rear spoiler alread Sold parts:Rob Barnard custom inlet manifold this was built when Rob had access to a program telling him the optimum runner lengths for an EFTE, this is a stock manifold that has had the runners shortened.This will fit directly to a 5E but a 4E it catches the clutch cylinder reservoir so I made up a remote mounting kit that will be included. No throttle body included, also the throttle pulley is for sale seperate. It fits a stock throttle body but I’m selling my auto body with the ECU.HKS F-con V pro ECU with loom and Auto throttle bodyBuddy club exhaust great condition even has the silencer bung!I have removed the pictures from the sold parts just trying to clean the thread up a bit.Ultra ignition leads in blue the best ones you can get perfect fit.Lightweight pulleys in blue some small marksRoose hose kit without radiator pipes in blue with stainless steel clipsSARD 550cc injectorsFuel lab fuel regulatorRW Developments custom alloy power steering potRW Developments custom alloy rad overflow bottle with roose blue hosrBC coilovers done about 4000 miles comes with all spanners all were greased from new to all free.Cruise wingsFront bumper in white perfectRear spoiler in Pink needs paintFootwell lightsRecaro covered centre arm restCarbon dipped interior door handlesCarbon dipped clock (time)Carbon dipped ash tray/cup holdersABS removal kitRecaro door cards with Custom door builds with vibe lite air components 16.5 cmTrd interior carbon set, window switch covers and centre consoleCusco master cylinder brace3G willwood 4 pot brake kit discs have quite a bit on them nearly new yellow stuff pads will fit behind 15’s 280mm with lines will also include rear braided linesCusco front lower wishbone brace scratchedC's short shift and shifter extensionGearbox with TRD clutch type LSD this doesn’t select reverse well at all but works fine in all the forward gears.Cusco type 40 front braceWhiteline rear anti roll bar usual rust fixed typeAEM wideband 52mm AFR comes with both dial facesTurbo smart E boost 2 the best boost controller I have used as new 60mm gauge type with box and instructionsGreddy remote mounted filter, thermostat and oil cooler setup. Puts the filter in the drivers front wheel arch comes with all fittings and lines.Black leather and red stitch gear garor and hadbrake gator98 spec indicatorsPassword JDM battery bracket with fitting kitBlitz cooling performer top hoseSard lower rad hoseMines exhuats wrapAlpha JDM horn painted whiteCusco Panhard rod all free adjustingFront towing eye needs paintClifford 650 alarm with 1 remoteTurbo blanketBlitz NUR spec back box will fit N/A or Glanza if you have the inlet pipe moddedTRD dial cover complete with 98 spec clocksRear caliper re-build kit for both calipersJSP polly shifter bushes brand new in the bagFSE fuel regulator with stock powder coated fuel rail and braided lines AN fittings etcWalbro 255 fuel pumpTRD engine mounts front two polly bush rear.Standard electric Glanza mirrors4EFTE TMD, Rob Barnard built, has done about 4000 miles since Darren at TMD opened it up to check everything was okWhiteline anti lift kitBlue throttle cable nearly newEarls braided clutch lineGreddy BOV with intercooler hose 60mm diaMomo Carbon wheelHRF manifold, TD05 turbo, Sard external wastegate, Oil feed and return pipesGreddy front mount with pipes to suit my TD05 set up will include all the silicone bends I have extra too will have stainless clips too.Apexi front mount filter alloy bend and Roose silicone bendsRecaro SR3 front seats with genuine railsToyota optional extra rear cup holdersRear cup holders Toyota but not EP91 specificRear cup holders Toyota but not EP91 specificPillar pod on 60mm one 52mm holeTuning developements throttle pulley in blue with dome nut and washerGenuine Varis rear bumperBlack and silver chequered fitted matts full setWhiteline front anti roll bar usual rustCusco type 40 rear braceCustom boot built with Sony sub and ampDry carbon Varis bonnetDrivers headlight with all fittingsGlanza owners book from JapanSection engine damperOptional extra recaro rear seatHave got loads of standard parts there will probally be more parts to list when I get into sorting out.Here is a link to my build thread there is all the picture I have ATM:>http://www.ukstarlet...showtopic=58738RegardsSimon Edited March 6, 2013 by Simon
Ryan-11 Posted December 30, 2012 Posted December 30, 2012 Ill 100% take the abs removal kit if the buyer back out
_shaun_ Posted December 30, 2012 Posted December 30, 2012 wow shocked is not the word hopefully a few of the parts am after will still be around when my bank balance recovers from xmas
Simon Posted December 30, 2012 Author Posted December 30, 2012 Just to add i will take a none refundable deposit on parts with an agrement to pay by a date and hold them for people.If you don't pay by the agreed date they will go back up for sale and i will keep your deposit.
_shaun_ Posted December 30, 2012 Posted December 30, 2012 (edited) how long would u give to pay in full? does the boot build allow you to keep a spare wheel? long shot but u wouldnt split the head from the block would you? Edited December 30, 2012 by _shaun_
mattyD Posted December 30, 2012 Posted December 30, 2012 I'll take the footwell lights mate do they come with the loom etc?
Simon Posted December 30, 2012 Author Posted December 30, 2012 (edited) ShaunDepends on what it is really but would wait for a month maybe a little more on the larger itemsWould like the engine to go as one.Need to loose the spare wheel mate that forms the box for the sub.Yes they do Matty i'll get them out and fire you a pic and price posted via p.m. Edited December 30, 2012 by Simon
Simon Posted December 30, 2012 Author Posted December 30, 2012 Do you still have the clean box?Sold sorry
_shaun_ Posted December 30, 2012 Posted December 30, 2012 ahh month would be plenty. thought as much with the boot build ill stick with mine then i guess. the speaker pods on the door cards how far do they stick out do you think they would foul a cage?
Liam_D Posted December 30, 2012 Posted December 30, 2012 Gutted to hear you're breaking mate Any pics of the carbon dipped interior pieces?
Simon Posted December 30, 2012 Author Posted December 30, 2012 They are the same as Matts mate but will get some pics up tomorrow
Glanza Mac Posted December 30, 2012 Posted December 30, 2012 I'll take the f con and throttle body mate Rob.
Glanza Mac Posted December 30, 2012 Posted December 30, 2012 Also first dibs on the varis front bumper if you sell seperate dude ThanksRob.
Jamie_VF22 Posted December 30, 2012 Posted December 30, 2012 RW Developments custom alloy power steering pot if its still there mate paypal waiting
Simon Posted December 30, 2012 Author Posted December 30, 2012 RW Developments custom alloy power steering pot if its still there mate paypal waitingYes it is P.m. sent
mattyD Posted December 30, 2012 Posted December 30, 2012 Do you have any more custom RW development bits mate?
mattyD Posted December 30, 2012 Posted December 30, 2012 Yes they do Matty i'll get them out and fire you a pic and price posted via p.m.That would be great mate
little dave Posted December 30, 2012 Posted December 30, 2012 Trd carbon bits please pm where to pay I will do it now
little dave Posted December 30, 2012 Posted December 30, 2012 And can I have a pic of rear cupholders please just want to be sure I would live these
starletburkie Posted December 30, 2012 Posted December 30, 2012 pm me best price on the 3 engien mounts del to ireland please
