Turk
    373
    London
3255 profile views
Turk's Achievements
Member (4/8)
  1. Ill buy the adjusters if you will seperate them?
  2. Pm me!
  3. Ill have these.
  4. If you would post ill be interested in the starter
  5. Are these rotas or spoon? Depending i will buy these
  6. As far as i know loads more wiring. Im pretty sure if you use the search option youll be able to find wiring diagrams. Another alternative to an emanage ultimate is a link g4+ atom which is slightly more expensive and is alot better because its a standalone
  7. Have you got the boot catch?
  8. ill take this mate
  9. need one for a glanza then. thanks hd
  10. Recently got an error code for my knock sensor. Looking for a used one for replacement as a new one is costly. Can i get prices posted to london. Or pick up if your close. Thanks
  11. are you willing to split? if so ill take the gearbox mount
  12. i had a similar problem and my coil was rusted which made it have a bad eart. cleaned it up and its good as gold now
  13. genuine seller. delivery and description was spot on
  14. Not trying to mess up your thread. But i beleive this will not work as the starlet clocks are cable driven and not electronically through sensor. I could be wrong but i highly dought it will work. Proberly a better shout on ebay as most nissans have sensors for the speedo's
