antheon2010
    116
    Malta
5601 profile views
antheon2010's Achievements
  1. Do you please have ep82 interior trim RHS ? @Bean
  2. WANTED DRIVER SIDE REAR PASSENGER DOOR CARD PLEASE. ep82 any trim. Kind regards.
  3. I need also wiring harness
  4. Do you have engine loom for sale please ?
    1. Nilz90
      Nilz90
      Sorry someone already interested in it. If it falls through I’ll let you know.
    2. antheon2010
  5. Hello
    You have any ep82 wiring harness please ?
    1. Nilz90
      Nilz90
      Sorry interior loom sold
    2. antheon2010
      antheon2010
      No the engine i am after
  6. How much for the loom please ?
  7. Hello Great process and attention to detail you have here I need some help as im after an ep82 engine loom if you could possible help . Thankyou
  8. Is this available pls
  9. Any help on loom please for a 4efte
  10. Can anyone tell me who is this guy please
  11. Yes you can run a boot if one is considering everyday use. Yes it can be used for added camber but one needs to unbolt it but as as for your doubt that it may not be locked up its machine out of T7 aluminium and have steel timeserts M26x1.5mm to take M20x1.5mm rosejoints. A lefthand / righthand thread would be adequate but in this situation its very limited.
  12. Yes depending how low you go. Its for people who love more b roads and push it to the limit on tracks.
  13. The lower control arm on a car must never be higher then parallel to the ground. On lowered eps the lca point sky high and as a result starlets do not corner but more over try to turn into a corner as the geometry is not in a good form. It depends on how low the car is. Im finalizing my design and taking various drops to maching various pin lengths. The ideal lca position is to be pointed downwards so it shall be parallel to th ground when the suspension dives such as at a stock height car.
  14. It depends how much one will go low. The vertical shaft that goes into the knuckle instead of the lca balljoint can be replaced to different length. I do have machined longer ones for more lowered eps.
  15. It depends how much one will go low. The vertical shaft that goes into the knuckle instead of the lca balljoint can be replaced to different length. I do have machined longer ones for more lowered eps.
