ToyotaTech15
    2058
  1. Good luck getting the pipe fixed pal, All sounds good with the new hybrid, cant wait for pics Gary
  2. ^^^ thats what i was thinking, but wasnt sure what happened lol Gary
  3. welcome to the club, Hope you find another n/a sometime Gary
  4. Hi mate, I'm from Forfar myself, there is plenty of Scottish members and meets so probs catch up at some point Good luck finding a V, Enjoy your stay! Gary
  5. wish I had came along to this, looked like a turn out. I'll be to the next one in one of my cars, depending when it Is Gary
  6. ^^^ Agreed, pics or gtfo!!! Gary
  7. This should prove a huge point of what these nippy 4EFE's can do, Dont underestimate what can be extracted from a naturally aspirated engine, Its a light engine and with detail in the right areas should bring out a fair little weapon Watch this space Gary
  8. Ok, well it's not going to do any harm changing it, halfords should be ok as long as it's 79w90, If it doesn't sort it then it can be looked into more but oil is the cheapest option Gary
  9. I would check gear box oil first, If it's dirty, the wrong viscosity or not enough, It will have a two thick oil film for the synchronesh to cut through, Change that if you have any doubts, to 75w90 Does it have a factory or aftermarket LSD? As that requires different oil Hope this helps Gary
  10. Nice parts you got there, As for the Drive shaft seal, the chances are a toyota dealer would charge 1-2 hours for a seal so it may come to £120 for labour plus parts on top but thats just an estimate of around £60 an hour. The rear shoes are inside the drum and will maybe be another hour of labour, my suggestion is maybe to get an independant garage to do the work, they wont charge half as much as a main dealer. The manifold is easy to fit and you could do it yourself, just 6 bolts and 2 brackets to get it off, one PCV valve hose and an earth, think thats all that involved, There is plenty of help here if needed mate Gary
  11. Right got these compression readings from the Toyota 4EFE workshop manual, All cylinders should be 185 psi (1,275 kPa, 13.0 kgf/cm2) or more, with no more than a 14 psi (98 kPa, 1.0 kgf/cm2) difference between the cylinders Your car is more than fine Liam Hope this helps Gary
  12. Hi mate and welcome to the club, Get some pictures posted up of your car, looks clean of it's the same one as your avatar Enjoy your stay Gary
  13. For whose information? I know toyota don't make parts that's why I said supply and not make I agree with G, and in my opinion toyota genuine parts are far superior to blueprint etc, I am just trying to get the lad the best parts for money, Also I have never had a toyota part that doesn't fit where as I've had loads of blueprint brakes etc that are wrong and don't fit Gary
  14. Hi mate, I would say genuine toyota parts would be your best bet, toyota supply a 5 litre bottle of 10w40 motor oil For gearbox oil it will be 75w90 unless its fitted with a factory/aftermarket LSD, Genuine denso spark plugs are also worth getting Also a genuine oil filter, Depending on how big a service you are doing there will be things like, Fuel filter Coolant Timing belt kit Brake fluid And inspection of distributor cap and rotor arm as they can become worn over time and often get ignored. They would be the main items unless you are looking for anything else Hope this helps Gary
  15. You can get everything seperate from toyota, obv the gears which are fixed to the shaft will require a whole new shaft if they are damaged, Also snap rings and circlips, will need to be measure if replacing as there are about 8 choices of snap rings for the box. I could get you a price on parts but as they are so small and there are so many of them a trip to toyota yourself would be the best option, If you confirm parts and give me part numbers i can get discounted prices but its maybe not worth the hassle. Hope this helps Gary
  16. @ dale, nope never heard oh him? What year is he in as there is a apprentice train centre and adult one both in notts. @ Baz, it's working on cars lol, I thought you were being cheaky Gary
  17. Right guys, I've spoken to my lecturer as I'm at college just now and he says that the only way to get on this scheme is to be employed by a toyota dealership, It's an expensive course, like 30k to train me for 3 years an I come to Nottingham science park to the toyota academy for two week blocks every 3 or 4 months, The training is excellent as are the facilities, I can post a few pictures up of the place Any more questions just ask Cheers Gary
  18. Hi mate, I'm a 3rd year apprentice technician for toyota Pm me if you want to know anything Gary
  19. What is the spec on the engine? What boost you running? Have you got a boost gauge or adjustable actuator? Gary
  20. Cool man, Hopefully there will be a good few meets next year, maybe catch up with you both Gary
  21. Welcome mate, Im from Dundee, there are alot of scottish members now good to see another joining Be good to see pics when you can Enjoy your stay Gary
  22. Welcome mate, Thats a nice EP youve got yourself Enjoy your stay Gary
  23. As the intake air is compressed by the turbo, its temperature will increase, using an intercooler will cool the intake air and make it more dense therefore ensuring higher power output Power gains will depend on other modifications on the engine and which cooler you go for as they all have different pipe routes and core sizes. Unless using a large turbo, lag isnt really a problem on a ct-9 to be honest Damn need to type faster lol Gary
  24. ^^^ mate your car is always clean Gary
