SiCaln
    11573
Everything posted by SiCaln
  1. no forget the 3 spoke idea altogether and get some nice black/yellow rims man
  2. well spotted on all those amends Phil, looks awesome man good on ya
  3. First take off the splash guard under the drive side. As picture, white plastic screw at the bottom of the rad. It can be unscrew by hand. Soon its unscrew the coolant should come out. Make sure you have some sort of bucket to catch the old coolants. Now open the rad cap at the top, anti-clockwise. so the coolant should rush out like the tap. After all drained out, i use a water hose and run it though the rad, to clean out all the dirty and rust. I even drained out the old coolant from the bottle. As mine was very very dirty. now pu; in the new coolant, should get the RED stuff coolant from toyota, as everyone recommend it. Now screw back in the white plastic screw tight. than pull the coolant into the top of the rad. Start the engine, wait about 10mins till the fan comes on, let all the air out the rad, fill it up if needed to. When all the air is out. Than you can put the rad cap back on.
  4. took another few of your guides man, really beefed up the how2 section thankyou
  5. Many of you connect your JAM FCC onto the ecu, as i have done, but it didn't work as it should, so i connected it to the MAP Sensor. 1st, unplug the Map sensor, theres 3 wires Cut the middle wire, not too near the plug, as you will need to use most of the wire for connection. On the JAM FCC there are 4 wires; ED = 12v live - Conneted to the IGNition behind the key switch. BLACK = Earth - Connected to the nut holding the MAP sensor. WHITE - Connect it to the wire coming out from the MAP sensor. GREEN - Connect it to the other half on the cut wire. Make sure the White and Green wires are connected to the right place. Or your car will start up funny. Get some strong 2 side tape, stick the unit on the wall. Job done
  6. Under the rear site, fuel tank cover. Unplug the harness and 3 screw to be removed, lid comes off. Than 3 fuel lines to be disconnect. Than by holding on the fuel lines and take the whole unit out of the tank slowly. Walbro pump is a bit bigger than the standard one. Now you have to cut the 2 wires goind to the standard pump, Blue=+ & Black=- . and connect the plug that comes with the kit Red=+ & Black=-. Put everything back together, because the pump its abit bigger, it will just fit in. and use the old filter and not the new one as the new one is too big and the tank aint got enough space for it.
  7. very nice man, what rear splitter is that, looks like standard one with centre cut out and meshed - me likey
  8. looks like an absolute beaut mate, nice spec too got any pics to whet the appetite?
  9. as we have discussed already, i really like it and anyone who doesn't is just wrong good on ya for being original!
  10. absolutely correct
  11. haha no way glad to hear you are doing well man, excellent news indeed beautiful work on the car too
  12. hope u dont mind mate, i used your quadlight convo in the how2 section as it was aces loving this motor so JDM
  13. Quad Lights Conversion on GT guide As i was doing my Quads conversion, had a Tutorial along. Unscrew the grill and bumper Take off the crash bar, easier to work with. Unscrew the lamp off the brackets. Cut out all the RED area, inorder for the quads to fit, as they are much bigger than the square lamps. I use drill and hack saw, easier with air saw or some sort. The brackets holding the lamps needs to be cut as pictured, but you can always get the brackets for the quads, save you cutting and holds better. as mines not that steady. After modding the brackets and fitted. Made my own brackets holding on the lamps, as i only have one at the top, you better to have one at top and one at bottom. Now drill as the pic shows, so you can screw the lamp in place. Testing with the grill in: Wiring the bulbs as so Here is a Wiring diagram i made: As its a conversion, you cannot have all beams to come on at the same time, only side lights can be on all times with either main or hi. Cannot have main and hi on together. After all fitted Extra info: High beam - HB4 / 9006 Main beam - HB3 / 9005 you may need to mod new bulbs, as the wings on the bulbs are bigger. as what i've done to my HID bulbs on the pic. The left bulb has been cut on the wings, as the right one has big wings on them.
  14. far as i know its the same size
  15. yea repair the starlet, give her the 206 lol
  16. yea welcome im not gna count the number of white Vs!
  17. really is clean bro good on ya
  18. no theyr more restrictive than 4efte ones
  19. yea was pretty jarring
  20. envy sell em on ebay for 595 + 20 for delivery
  21. honestly looks awesome man, well worth the frost bite!
  22. sorry yea thats what i meant normal gearbox and aftermarket lsd fur de winz
  23. gotta be honest bro if your doing clear headlights, u need Glanza clear lights, not just clear indicator lenses they do look lush tho
  24. true. get an aftermarket one
