SiCaln
    11573
Everything posted by SiCaln
  1. very smart, nice and clean example
  2. you more than did bro thankyou, mines gonna be a bastardised mix of Nakamichi speakers and Sony amps and sub
  3. no your spot on there buddy whens the convo gna take place then mate?
  4. I don't have to explain myself to you...but i will, i was looking on ebay had 'glanza' in the search box with inc. contents ticked and that came up!
  5. Click here if you dare!
  6. SiCaln
    im new
    welcome to the site, look forward to seeing the car
  7. Outer Foam Rest Having already removed the top from the bottom of the seat, you are now ready to tackle the job of replacing the outer foam rest. Firstly, look at the bottom of the back rest and you will see a strip of plastic with 2 staples in it. Remove the staples with a pair of pliers, you don't really need them to be honest. Then you will see that the seat is held together by these plastic retaining strips which hook into eachother, I slid my finger in between the two and pulled them apart. Then lay the seat on its back and lift the centre cushion upwards, it is fixed at the middle with 2 retaining hooks that just swivel out. The black fabric on the seat also has retaining clips on the side that need to be removed as you can see here. I found it made the job a lot easier if you remove the centre cushion, you do this by sliding your hand in between the top of the cushion and the seat frame, and remove the fabric from the 3 hooks indicated here. Then after removing the cushion, roll the fabric upwards undoing the clips on the side as you go to allow more fabric to come off. You do not have to take off the plastic back release levers at the side of the seat to do this. The old foam is stuck to the top of the chair but will just pull off. You can see the damage on the foam removed from my seat. Here is the comfy looking frame of your seat waiting for the new foam to be installed The new foam slots in to place over the skeleton of the seat, I would advise re-glueing the top of the foam together as it was previously. Now just roll the fabric back over the chair and down. You will have to re-attach the fabric of the chair to the 3 hooks at the top of the chair shown earlier first, secondly attatch the centre cushion back in the same way over the 3 hooks and the 2 retaining ones in the middle of the seat. Once the fabric has been rolled down to the base of the seat, connect the two plastic hook strips at the bottom of the seat fabric back together and re-attatch to the base of the seat by reversing the instructions for disassembly. Seat as good as new and old foam can now be recycled for packing material. vucrG
  8. Side Bolster Foam I had noticed that my newly purchased seats needed some reconstructive surgery carried out. I purchased the required parts from this store (excellent service) Capital Seating , they also provide replacement fabric should it be needed. I purchased the SR/Sport outer backrest foam and Speed RH bolster foam (you may however need different parts dependant on model of seat). As you can see from my seat, the driver's RH side bolster is damaged and torn, so needs replacing. After removing the seat from the car place it on a smooth solid surface with the base of the subframe facing upwards. The first job is to remove this from the base of the seat, which is done using a torq/posidrive screw driver on the 3 bolts on each side of the seat. This removes the rails from the base of the seat, so you can gain easier access to the clips and fixings needed shortly. As I am replacing the rear foam too I next seperated the top part of the seat from the bottom part, by firstly pulling off the side cover as shown and used a flat head screw driver to remove the cir-clip and washer shown and then un-doing this large phillips screw on the side to seperate the top and bottom, you also have to release the backrest using the handles that drop the seat forward. Now pull the metal work off the newly released fixing and seperate top and bottom. With the base now removed from the bottom, begin by sliding a flat hear screw driver under the clips indicated by the yellow arrows and removing the thin pole (shown in the last pic here) from it that holds the fabric in place over the foam. Lastly, Remove the last piece of fabric wrapped over the white tape (shown) at front and back) Now simply pull off the fabric and examine damage, as you can see I had attempted a temporary repair with tape, but to no avail. This picture shows what is holding you in the seat, a nice delicate thick bar of metal! I found it easier to sit the new foam in place first and then simply reverse the process, wrapping the fabric from the inside, by centre cushion, around to the underside of the chair, then hammering the retaining clips back down into place to hold the fabric still. Et Voila! Your newly repaired and comfy seat awaits you!
  9. Just a quick one for me, took the day off work on saturday, and done a few little bits firstly I've repaired the Recaros and made a how2 (Click Here for guide) of changing the foam inside, secondly got my new winter rims and fitted my winter rubber to em, Uniroyal Rainsports ftw. Here is them naked - just gotta order some centre caps for em, then they'll be good to go on Cheers Keith your a legend
  10. like it, but i would prefer it followed the swage lines of the bonnet and went to the left and right at the back rather than straight
  11. I believe it sits taller than the 4e
  12. looks like your gna have to follow in the awesome customised footsteps of mr Scutchings im fraid
  13. just read thru your post again, where did u get the 2.5" pipe made up man need one myself, also how much
  14. do i? dont think I've seen em, got a pic?
  15. also theres some konis for sale on tgtt
  16. yea we still have 2 sets by APP the experts in Japan for brake lines
  17. she does make good Tea, think thats where i got it from she would also love 40+ Starleteers parked along the street
  18. firstly Jo your no tag along more than welcome secondly Gaz's motor has been off the road for ages
  19. thanks man, glad i dont offend u i work 7 days a week til at least 8 so prob wouldnt b able to make it all things considered!
  20. not great man, plus i can see a house and a van behind he window in the 'car'
  21. lol nice Mikey that sounds like a very comprehensive kit how much did it cost?
  22. got my Jap plates from Halfrauds
  23. very smart indeed man, do like t he white too tho take it uv got a boost gauge already?
