Dan Evans
  • Content Count
    1573
Everything posted by Dan Evans
  1. there will be oil sprayed all over the bay if it was piston rings mate, happened to mine and im re-building mine now. Just take off he top mounted intercooler and pipe connecting to the turbo, and its easier for you to get at then. if you were closer id come give you a hand mate
  2. it wont be piston rings, unless theres alot of oil coming out of the top of the rocker cover breather pipe
  3. first thing is to look under the car at the turbo, and check the oil feed pipe, if thats ok, the undo the intake pipe from the turbo (black plastic pipe) if theres alot of oil in there, then it has gone, if not stick your fingers in the turbo ( be carefull, blades are sharp) and wiggle the shaft to se if theres alot of movement.
  4. your Turbo has gone booooooooooom, by the sounds of things mate, check the oil feed, if its ok, wiggle the shaft in the turbo to see if theres alot of movement and to see if theres oil coming out of it.
  5. thats were i was today for about 4 hours LOL
  6. give it a couple months and il be up for it
  7. N88 DJE, this plate will follow me around for quite a while N = November 88 = 1988 D = Daniel J = James E = Evans
  8. joel it looks identical to your car!!!
  9. 1000bhp out of a 3000gt? Id like to see that. good luck mate
  10. looking at getting this one, http://cgi.ebay.co.uk/Toyota-Starlet-Turbo...=item27b0d06d37 What do you guys think, seems abit pricey??
  11. check the inside of the screamer isnt hitting the wastegate flap which may cause it to not open, hence the lack of boost
  12. looking more like mine every day lol
  13. im already going to this with a mate of mine in his RS focus. would of prefered to go in the glanza but never mind
  14. cheers dude, much appreciated, after the engine is done, more carbon goodies to come lol
  15. As you know im re-building the enigine,. The Crank bolts will be getting re-placed, but just wondering what the advantages of having ARP ones over standard would have? and who does them?
  16. im just going for a TD04 on this engine, but the 5E im going TD05 ball bearing.
  17. cheers dude Not sure about the front end yet, may get a varis carbon one made??
  18. id stick to getting the silver ones with white wheels.
  19. looks good mate, did you spray paint them or brush on?
  20. LOL... my glanza was pushing 172bhp before the piston wet bang, and i raced a GT4 that was fairly standard, off the line i had no chance, from a rolling start at say 30-90 i kept up well. But if your saying you have gone from a stand still, and beat the GT4, then congrats, you must have a totally amazing Glanza....... or an amazing imagination..
