ryan lang
    8959
  1. yooo guys and girls need a mahoosive favor from some sexy sheffield members my window frame seals got damaged during the break in, and now they leak water, theres a guy from mx5nutz who lives in the s11 area of sheffield who is giving away his torn roof, apparently the window seals are good and it only leaked from the tears in the vinyl was just wondering if one of you legends (if really local) could go pick it up and bring it to japfest for me? theres burgers and snuggles in it for you ryan
  2. cheers bryn gunna be getting the white lab coat on, zip up my pockets and experimenting the shit out of this one see what can be done with little to no money as possible obviously ill be buying ggenuine gaskets and rebuild bits, but for more powers ill be seeing what i can put together
  3. yeah josheyboy006 will be able to sort you out with a set of sr decals i imagine dude. should fade like the originals either
  4. if you can get a pic, ill happily label them for you with the inlet manifold off, everything is easily visible
  5. no worries, i did have them written somewhere, but not a clue where they've got too :/ EDIT: found the document, its got all the tolerances etc, except that one :/ lol. if you can wait until wednesday i can check it for you on auto data at college?
  6. the 0.35-40mm may do it fella not sure of the tolerances though. another thing it could be, it on the inlet cam gear, theres a split in it, with the gear end of the cam facing you, twist the thinner outer section of the gear anti clockwise as much as it will go. i had this on mine when we put 5efhe cams in. did this and it went
  7. finally got the other 2 wheels sprayed in satin black just need to get a new centre cap, and strip all 96 studs of the purple paint then the wheels will be done also polised up the wing mirror base and finally managed to get them not to flop so i could say good bye to the cable ties ANDDD trying to stay true to my 1st post of this build thread, planning on keeping it clean
  8. ill have a nose for you mate, pretty sure they are in the back of my brothers nissan track/drift/storage bitch
  9. the main water pump hose runs along the back of the engine which goes to the thermo housing, then you have the small hose that comes out from the main water pipe which goes to the throttle body. then you have 2 for the heater matrix, (in and out) then you have the pipe that goes to the bottom of the rad
  10. is it actually? id have said black ones are rarer? only see silver ones about, never see white or black ones apart from the members on here also, which splash guard of yours is missing? pretty sure ive got both of my old ones kicking about somewhere
  11. mines around 30MPG but its all about the SPG
  12. cheers boss
  13. read that as being bricked :s lol
  14. new tyres have been fitted went for rainsports again because they are quite frankly awesome need to raise it up a little because the added tread is now catching the arch liner :/ also found these kicking about the brothers s13 spares bin adjustable actuator and a brand new unused oil return pipe also the younger brother has discovered a hidden talent 13 and welding cage anyone?
  15. not alot but stripping the head down for 5 minutes earlier so thought id take a couple of pics
  16. thought thats what time we had to be there? lol
  17. might aswell buy a fucking mobility scooter
  18. if you can get hold of a hand held vice clamp that bitch on the top part that comes through the screw, or take the whole strut out and do it in a bench vice. make sure you put a ring end spanner on 1st before doing these, and use springs compressors i know of a few people who have use mole grips, but when i used them on mine, it absolutely ruined the bar that sticks out of the top of the top strut nut
  19. i did a mint diagram on how to undo these somewhere
  20. looks weirdly like an n/a version of matts old track glanza haha
  21. minus the hks it looks cool lol bonnet has raisers ^^
  22. haha yeah forgot about that tbf lol. you need to bring your mumsy too haha
  23. lottie you can find your own way back to mine then hahahaha okay james boyo, see you there
