chris H
Member-
Content Count
159 -
Store
Calendar
Everything posted by chris H
This was on the magnetic sump plug Piston. no scratches on skirts or evidence of blowby piston ring gap 0.55mm (gap is at 12 o'clock) what say you?? lol there is a literal drop of oil on two of the intake valves so looks like the injectors were spraying fuel on to them and washing the oil off and into the combustion chamber hence the blue smoke. The cars used about 2 litres of oil in 700 miles!!
Just quickly, i'm on as we speak checking the pistons over and there's no signs of blowby on the pistons. Can someone tell me what the maximum piston ring gap can be? I've took the rings off the piston and put it in the bore. tested the gap and it's 0.55mm. sounds ok to me but can someone confirm? cheers chris
Lawsy, that's exactly what i was thinking mate, gonna pull the pistons out this afternoon and check them over just for peace of mind but it's doing my head in lol
No mate, not got a catch can but then the breather pipes are venting to atmosphere anyway so it's deffo not that.
just let me know which one it is dude and i'll sort you one.
Ok guys so the engine was built 1300 miles ago to standard spec, new rings and rehone, valve stem seals, oil and water pump and gaskets, now the car runs great, ticks over a little quick but still runs good. if i back off the throttle from example 70-80mph and let the car roll down to say 60 as soon as i touch the throttle again there's a plume of blue smoke from the exhaust (quite a bit of smoke), it lasts about 4-5 seconds and clears up till i do it again. I thought it was the turbo but i've changed it 3 times and it still smokes exactly the same. Today i ran a compression test from cold
take a picture of the one you need and post it up, if it's the cam cap you need with the long stud on the top then i'll have one on my spare head. on the alluminium cap there will be a id mark on it like E5 or I3, something like that, let me know and i'll sort it for you fella.
same from me. top man! bumper was exactly as described. top marks. ;)
Silver glanza spotted newcastle
chris H replied to ep91_glanza's topic in I Spy, Have You Been Spotted?
I'll pm you my number matey and if you need a hand just gis a shout. -
hi mate, yeah it's me, i work at nixon hire lol so always dotting about there lol. yeah i've got a hks bov on it but you've gotta hoof it before it'll vent! What van you in? i'll give ya a wave next time i see you -
N plate with clear back windows?? -
Iamlegend's TDO4 White Glanza V 1999
chris H replied to iamlegend's topic in EP91 Glanza Progress Blogs
Woah ashley ya donkey! lmao.... i'm gutted for you mate! was looking forward to the result -
Cold compression test done today 180 psi across all 4 cylinders, it only had the engine built 1300 miles ago so don't think it can be piston rings. I noticed tonight on my way home at 30mph rolling down hill in 3rd (foot off the throttle) car hadn't been revved hard at all, i touched the throttle to to keep up with the traffic and noticed a tiny puff of blue smoke in the headlights of the car behind. What i'm thinking is that one of the valve stem oil seals on the intake side is leaking and the oil is building up on the back of the valve when the throttle is closed, when i touch the throttle
(Long Term) EP91 Toyota Starlet Solida Build
chris H replied to Solida EP's topic in EP91 Progress Blogs
Yey another 5 door, i've got one too! met green gls as well as my glanza -
Hi mate, welcome. ;)
Ok guys just fitted another turbo (known good one) and it's still doing the same thing, no smoke till i rev it hard then back off... touch accelerator pedal and a swirl of bluey smoke from exhaust for about 4-5 seconds then clears up. Valve stem oil seals??? anyone?
Looking forward to seeing this!! gotta love a sleeper
Welcome along mate, get some pics up dude
congrats mate! i just started my new job yesterday! soooo good to be out the nissan plant and back into plant machinery!! well done!
where would i get that done mate? i cosidered rebuilding mine but thought if it goes tits up i've lost 80 odd quid
Off the top of my head it took 3 weeks in total but i was just plodding along at my own pace. Cost wise eew i've not really worked it out lol, here goes; Gasket kit (toyota) 140 water pump (ebay) 30 crank (uksc member) 100 crank main bearings and rod bearings (usa ebay) 90 thrust washers (toyota) 35 oil pump (toyota) 95 timing belt kit (tm developments) 55 oil, filter (tm developments) 35 4life coolant (toyota) 25 thermostat (toyota)23 exedy clutch (ebay) 95 piston rings (toyota) 100 machine work (head skim, crank regrind, cylinder hone. and 4 crank crack tests 270
from cold take your rad cap off, turn your heater to the hottest setting, start the engine and top up the rad, let it warm up with the rad cap off and that should expell any air in the system mate
More to come, just need to upload pics to photobucket
