shaq
Member-
24 -
1562 profile views
shaq's Achievements
Okay update,cleaned plugs replaced pcv a big issue causing oil carbonisation and other blow by issues.cleaned inlet.cleaned iacv cleaned injectors.done.
Lube gbox cables try and get maybe slightly longer cables bent bracket where the gbox cable is attached with the metal plate slot or bent plate worn bush.the plate can be pulled with pliers or a tong.that's a nice line for the females I need your tongs my gearstick is crunchy or my gears are grindy.hey tongs my 2nd gear is not engadging
Check your clutch bolts loose or missing and cracked mounts,sometimes the mounts okay can be a crack on where mounts bolt onto engine is cracked,I've cracked it and fixed twice taken to engineer,could be extra meat on new clutch or un evenly torqued bolts between gbox engine or even clutch plates,release bearing!l
No adjustment,lube your cables and grease/lube shifter,wd40 moly spray,you can cut the cable cover a small bit spray.seal it with any adhesive and rubber.check the tube.I had the same issue SOmE times can be cut worn bush not keeping the cable straight just have a look lube the ends can work too.
Battery first,terminals and terminal wires and fuses ground too(corrosion and rips on terminal cables)alternator cables.
<iframe width="480" height="360" src="http://s1378.photobucket.com/user/reptillianhunter/embed/slideshow/"></iframe> http://i1378.photobucket.com/albums/ah88/reptillianhunter/IMG_20171003_060608_zps6pfdpdhs.jpg http://i1378.photobucket.com/albums/ah88/reptillianhunter/IMG_20171003_060608_zps6pfdpdhs.jpg okay the 2pin connector is for o2 sensor,what is the 6pin connector for?.where does the 2 pin for o2 go?
Right my ecu part number is 89661-10160 for 4efe 26p for manual.i need help figuring the secondary o2 sensor,im not very competent in electrics,wiring.actually as since I saw the wiring did not make any sense. I just got done repairing knock sensor cleaning intake iacv,butterfly intake(fixed ecl),replaced the pcv valve,did wonders in smoothness response ,especially the pcv.she is still thirsty high fuel consumption.so started digging around and found my secondary o2 sensor not plugged in and just stuff making no sense when the opened the center console the gearbox shifter cover.the wiring is all messed up. I've posted some pics I'm just baffled.I need that baby hooked up any assist appreciated.pinouts to ecu or better still splice insert the wires from point a to b solder etc. Here are pics hope helps the next guy in my position with just wires making no sense.some say its pointless to have it plugged no harm but my research says it does have an effect on some cars and once you guys assist I'll give you feedback if it does affect efficiency. okay the 2pin connector is for o2 sensor,what is the 6pin connector for?.where does the 2 pin for o2 go?
Drive shaft play and knocking help please
shaq replied to HarrisonS's topic in Drivetrain & Transmission
alignment went off you hit potholes(tie rods checkem too for wear)/if your boot rubber split and water entered /even after replacing sometimes the driveshafts cool but will get noise the annoying clacking on full steering turn slow speed/but goes when you go above 10mph.check your bearings too while you at it -
All im saying before you do anything know limits of your car and increase skill,skill is also worn tyres completely worn pads and a wet road.especially mud where now you will learn about momentum and throttle control finesse or several crashes cursing and crying my baby ,although the later never happened because I love my baby and there's a method to my madness.left or no left foot braking skills and practise.
Guys my under steer is not bad I'm.but I'm not excited ,I was trying to be humble and not say I'm a natural plus I wanted to share knowledge.so give and receive universal law.hey Collins go yo my gearbox thread and tell me what gearbox I have !I've posted pics.plus I'm addicted to corners I can't help it i go mad.I know I need an intervention guys.but all I'm saying yeah the understeer is a design safety so you can learn throttle control on limit .but like I said with illegal no thread stock skinny 165/70/13 I'm telling you skills went off the scale and you put a crash wall inches from the side mirror and then get under over steer everything ,it gives you the reactions for sure.mad skills ,but bad for pocket and especially if small things make you sleepless on your car like small leaks and small stuff.been but I'm hey handle and they handle for sure.check the video.I'm actually the calmest on the limit.basically after no riding 2 years you drive it like a motorcycle.all I'm saying before you add this mod and that mod add reactions skills and muscle memory.it takes skills beating faster cars with your stocky n/a starlet especially in its element of mediumish traffic and tight bends and just patience of changing lanes .that's all who said I'm excited .I need no tips on driving only mechanicals.
This is what worked for me guys hard setup upfront and softer at the rear.okay had stiffer springs allround,then swapped rear for softer springs ,it solved the understeer,i actually swapped the rear were too hard on my back especially country roads(on top what the guy told me were original springs for rear new,they werent were mushy soft kind of like a slinky toy,but there was a flipside).I've had the stock tyre sizes and wider tyres,worked on both,but again many factors involved you do get slight(minute) understeer but its learning the feel of the car,like camber of road,bumpy road,uphill down hill,muddy wet, weight shift ,too much power going in or how quick you turn in(basically managing weight shift),grip of tyre (I've run the stock yokos bald maximum attack foot down,no thread left ,thats when i got understeer),but you dont get the scary understeer these things have,there is a tendency of lift off oversteer if you aggressive,but basically i manage subconsciously.its predictable,even with no thread left on certain tyres which is how i wanted to get my skills and reactions up,a little unpredictability. Without getting too technical ,you can liftoff ,turn in turn out,left foot slightly,although liftoff and turning the steering out and back in the turn.you know you have to be one with the car,its like riding a bike you turn perfectly,then when you learn about turning countersteering you actually turn left to lean right at speeds above 15mph on a bike(you learn this in emergency drills)but you do it instinctively,when you do it consciously it gets weird at first. What i am saying is basically findout the limits of your baby at different scenarios or situations so will help your skills. its all about the corners .check this out ,and this starlet is beating a gtr ,and does it on corners not possible if it was understeering. I had to share my 2cents of limited experience and knowledge,would love to hear all your idears in improving handling especially UNDERSTEER. THIS VIDEO IS MORE INTERESTING THAN MY RAMBLINGS,AND ITS POWER TO WEIGHT RATIO AND HANDLING NOT CRAZY POWER.STOCK POWER N/A STARLET WITH BASIC MODS YOU CAN DO IN A DAY FASTER THAN GTR.GET THE HANDLING RIGHT THESE CARS ARE FUN AND I KNOW I CAN DRIVE MINE BEYOND ITS LIMITS AND SOME.anyone can put his foot down in a straight line few are wired to drop a gear and maximum attack corners. >http://<iframe width="560" height="315" src="https://www.youtube.com/embed/s5FMshSjpjM" frameborder="0" allowfullscreen></iframe>
please go to my thread help me identify my gearbox
my lsd is simple rev the engine on a dry road dump the clutch its goes like this wheelspin lsd bite traction small wheelspin bite traction then lock and unlock lock and unlock it literally digs in or bites the road .what im describing is the bitting and no clutch burning smell if you did not have lsd you would be smelling the clutch and just wheelspin and not moving forward much,with lsd its wheelspin then locks you move forward unlocks locks you get traction and move forward.(i kniow),also when you scandinavian on a dry dust road handbrake counter steer it like the fronts really glued down,i had a normal c140 and then got an unknown gearbox which has lsd,infact go to my thread and see the pics if your gearbox looks like mine its lsd.now if you need some tips to overcome understeer on these starlets please do let me know.you will be oversteer happy.infact if you go to me thread and identify my gearbox il let you in solving the understeer plague.bro i dont care about straight line speed but the corners,thats where they shine ,and i practiced with completely worn tyres to make things interesting,cause my baby got too predictable liftoff oversteer just gave me suprises when i didnt want the oversteer.but if you dont know what you doing you will crash terribly they are light.
cool yo check them images.thanx.
okay we like dirty pics but not this kind(excuse the leaky driveshaft seal needed to check parts seals and stuff,thats why i need you guys/i know drop the gbox as soon as i get a chance,i dont like her leaky) lo and behold the gearbox that gotaway from toyota area 51.it clearly says ''3''. unless i i got a prototype gearbox woo.but im hoping its just a known gearbox make it easier getting parts i need for her. http://imgur.com/aatgpBg http://imgur.com/YljXS0H http://imgur.com/JNuyTT5 http://imgur.com/4xTcNXA http://imgur.com/r45SNAf http://imgur.com/letWPku http://imgur.com/c6pisfQ
