Been on this forum a fair while. Already had two projects on here. Well its best to say failed projects... This is the car which made me break the starlet and stop the project all together! This car is not going! Main reason I am on here is because you lot really are a great bunch, alot of you really know your stuff and my club/forum hardly post or give input to builds.
The car is a 1997 daihatsu avanzato trxx r4. 660cc turbo and 4WD!
I really got one aim for this year and thats to get over 120bhp.
This is an old photo now but hey ho!
1911772_547776472047462_5764925013410223
Got a mate who welded the barbed fitting onto the magnesium rocker! Here is the oil catch tank set up. I got a hose going from the bottom of the tank to the underneath of the car to create a vacuum to suck all the crap out.
12472824_1162905797055551_56245945229754
Following spec so far
HKS dx30 turbo. HKS dynographs show 126bhp at 1.2 bar. Although you can run more pressure.
custom tubular manifold (not fitted yet)
Front mount intercooler (its a wepr core 8))
starlet injectors
apexi SAFC2
turbosmart FCD2
ghetto uprated engine mounts
PCV delete on rocker cover, barbed fitting welded on in its place with a oil catch can
AEM wideband
Defi adance ZD (fake) engine monitor
alloy radiator
lower springs
custom stainless 2" exhaust system with shotgun exhaust
bolt on archs
13x7 extreme offset wheels. no idea if I will be running 175/50/13 or 225/45/13 tyres yet.
Thats about all the stuff which matters!
But this is the spec wihich will be happening over the next year! This should get the car to about 140bhp fingers crossed. I am going into untouched territory really. First person to push one of these over the 120ish BHP mark in the UK.
Everyone from the top except the apexi SAFC2 and turbo smart FCD2
emanage blue with ignition harness, injector harness and 3 bar map sensor
AEM water meth injection kit
Intercooler spray kit
custom inlet
Thicker metal head gasket
Uprated timing chain kit
coilovers £1200 without postage from japan!!!
Custom uprated front brakes. No idea who I am going to yet. Probably WMS. issue is I am running 13" wheels
Braided brake lines
uprated rear brake shoes
strip the car out with two bucket seats and harness's
all the ultra racing braces
possibly areo parts if my pockets are deep enough to import it all from japan.
One major issue I got at the moment is finding a mapper who will touch the car! Already asked a few companies (wont name any of them) who are unwilling to touch the car because its 660cc pushing that much power.
Over this week I am replacing all the bolts in the engine bay with stainless steel units, wrinkle paint the rocker and do a few other little things.
Edited by mas12555
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
Love a Kei car build!
Spec is impressive and plans sound great aswell buddy :)
I love them. Good friend of me bought superspats (hes an old UKSO member) old one and I love it. Its 110bhp and FWD. Even that beats corsa vxr's and its only 110bhp.
Already spent a small fortune on it! The turbo is made for my engine by HKS and its £1200 brand new! I got is used off a mate and still payed silly money for it. Also planning to go external wastegate once i get the tubular manifold on. At the same time I will send the turbo off to get rebuild and a billet compressor wheel made.
Here is the manifold
12805790_1148921191787345_47310245520255
If only i had about 4k I could by a storia X4 take the engine and running gear out of it. Would mean i would have 713cc, easy 220bhp, uprated drivetrain and lsd front and rear.
Have you tried Ed at fusion? He mapped yasers 250hp gtti which is alot of power from a 3 pot!
not yet mate! I know he does amazing work and he has mapped a few friends car. He really knows his stuff. Only issue is I got told by a few people that he doesnt go near emanage blue. He will only do ulitmate which doesnt work with my ECU without serious modification to the circuit board.
fecking sweet if its anything like a capucino engine then theres loads of tuning potential and revs increase
cant wait to see a hard boost onboard vid :)
Over in Malaysia they love these things! highest power daihatsu is a 3 cylinder with a 1L block running 400bhp. Theres a few 4 cylinders running 250bhp mark.
Standard engine a fair few of the Malaysians have run them at 150-160bhp without any water meth or thicker head gaskets so my targets are fairly realistic.
The turbo I got is amazing. full boost at 2500 and holds it all the way to 8500. the rev limiter is at about 9500. HKS advise to only rev the car to 8000 with this turbo. Dont really know why.
Edited by mas12555
He does do blue. Yasers is on a blue and he said hed do mine. Ultimate doesnt work with the gttis either
Ahh sweet! I cant remember what you have to do now but its something to do with the ignition timing. Few people have ran them in Malaysia and just not wired in the ignition part of emanage. There is a company out there who will mod you ecu and wire in the emanage for you.
I will be going Ed then. Hes local and knows his stuff.
Paint came today I spent the evening on the rocker!
The rocker was already preped but I deicded to cut off the ugly OEM intercooler brackets. Just used a hacksaw to cut them off, bench grinder to grind them down then I used a file to give it a nice finish. I thought I did a good job of it.
12924369_1165686750110789_12987939398687
I then painted the rocked. I used VTH black wrinkle paint. Wasnt too sure on the stuff but the good reviews made me want to give it a try. Gave the rocker three thick coats. Then left to dry for about an hour. The more eagle eyed guys on here will spot the paint from the starlet on my "painting board". Do miss the starlet.
12919703_1165686700110794_24610590305653
I then baked the rocker in the over for 25 minutes at around 100 degrees C. My mum really wasnt happy with this but it gives the best results! So here is the rocker all done. Should look abit better after its fully dry. Takes about a week! Looks good with the red spark plug cover!
12920432_1165686656777465_90683458478281
12936627_1165686473444150_48929813307100
The rocker cover is all dry now and looks amazing! My mass loads of stainless steel bolts/hardware came and my oil filler cap. The filler cap was for a starlet and I was hoping it would fit being that toyota own daihatsu. I had to modify it for it fit but its worth it! Looks epic.
12931164_1166541546691976_49895443051301
This is such a cool little motor, just had a read through and i can't wait to see how you go with it, that 2.5k spool and the figures your looking to make will be very impressive. I will be keeping an eye on this thread.
I'm amazed with the turbo. Really is magic but then it is made by HKS specially for my engine.
No idea what I plan to do this weekend but I got new discs/pads,wishbones with balls joints, track rod ends and anti roll bar bushes. Should make the car drive really nice.
Anyone know any company which make custom braided brake lines? Need some for my car. Also got a master cylinder stop coming from japan.
Edited by mas12555
Hosetechnik do, local to me. I used my starlet ones on the gtti fitted the same
Sweet cheers mate. Will give them a ring. Will need to send them all my house etc. I could make my own using the venhill system but venhill is expensive.
Anyone know a company who can make custom brakes? Will be looking at keeping the standard disc size which is 234mm and just uprating the a 4 pot caliper.
The discs cant get much bigger than a 234mm otherwise they would never fit under 13" wheels. Half tempted to just run with standard discs and just get some 4 pot callipers made to fit on. If I get warping issue will get some custom discs made up.
Theres a guy on here that deals brakes but for the life of me i cant find him lol
If someone finds him he may be able to help you
James
Edit: WSM brakes ..... his name is keri
Edited by jimmymac101
James
Sweet cheers mate :) working today so can't really get any work done to her which is annoying
Man this thing is so damn cool! I would love something like this as a daily!
they make awesome daily drivers. The car was meant to be my daily while I built the starlet but I just fell in love with it.
They are great in fuel, full tank of shell V power is £20 and that got me about 250miles of town driving. Not very relaxed driving as well. I found on the motorway it's even better. I got from reading to Bristol on £5 of fuel with a starlet engine in the boot.
They are nice to be in as well. Seats are comfy, all of then have air con as standard and some have crazy options on them.
More work done today! I fitted my stainless steel manifold today. Looks epic! Although its a very tight fit which may be an issue. The car is going off in a few weeks to get a tial external wastegate fitted, standard wastegate welded up on the turbo, turbo back exhaust fitted, wideband, lambda and EGT bungs fitted.
Main issue with the tight room is that I can only run the screamer out of the bonnet. I would prefer it to be going under the car but that isnt possible. Bonnet exit it is! I am hoping to see better results with a decent external wastegate than the internal wastegate.
Right here are the pics! You can see how tight it is.
12924323_1168855123127285_29320841099011
12718389_1168855279793936_36883138873236
12919784_1168855349793929_69976815849635
12472579_1168855216460609_22117012997485
12376834_1168855406460590_83189327541442
12963885_1168855259793938_43434075370982
Does anyone know the best place to get a 38mm wastegate from? Dont really know what the best are either. I was just thinking good old tial or turbosmart.
Alot of you guys got me on good old bookface so you will know that I did abit of an impulse buy last night. Mint condition kevlar border bucket seat. In large as well, which means I can fit my ghetto booty in it.
Does anyone know the best way and the best product to use for cleaning the seat?
12963873_992935007442199_493366756702551
12932615_992935004108866_112758143674935
12933063_992935014108865_321761131144292
I also fitted my braided oil feed and return on the turbo. I drilled out the factory oil return hole in the block from 17mm to 18.5mm then I tapped it to m20 1.5 so I can screw in the AN10 fitting. I magnetised the drill bit, used loads of grease and I am dropping the sump next weekend just to make sure there is no metal fillings anywhere. I cant risk it. I am pretty happy with myself and the end result!
13015347_1175409265805204_59624003599712
13001280_1175409375805193_13791370576318
12963782_1175409319138532_91746621241726
I also got loads of braided line and AN fittings to do every fuel line, water line, oil line in my car. Also got an oil filter relocation kit coming.
I am about 3 months behind my deadline. Car was meant to be done and on the road for japfest! Whoops.
after hours of research and speaking to people I have come up with some coilovers which will be good spec and wont cost a bomb.
Front coilovers
I already know that corsa b front coilovers fit my car as I made some cheapy ebay ones fit. Getting a set of gaz ultra low front coilovers. Need the ultra low because the normal coilovers sit very high and dont give much travel once its lowered. Adjustable height, damping and will be getting some cusco avanzato camber plates so I got adjustable camber.
Rear coilovers
The rear suspension on my car is seperate spring and shock. Spring sits on the axle, shocks are separate and sit at a 25 degree angle. Rear end of the car weights naff all. Only the weight of the shell and the rear axle. The fuel tank is in the middle of the car which makes things ideal.
I weighted the rear end and it near enough weights the same as a classic mini. Well just by luck classic mini rear coilovers measure up to be a perfect fit. Protech do a lovely set of rear coilovers for the mini. 14" long will be fine, adjustable height and damping.
Spring rates
After speaking to a fair few people in the know. We have come to a rough conclusion that 200lb on the front and 100lb on the rear will be a good starting point.
The front is simple enough 200lb spring with a 4lb helper spring to keep the spring located.
The rear is a little more complicated. Because of the 25ish degree angle the coilover will be sitting we need to do some maths to get the right spring rate. A 125lb spring will be near enough 100lb when its at a 25 degree angle. Once again will be running a 4lb helper spring.
