DKDK Posted April 2, 2016 Posted April 2, 2016 I found som alloy's i world lige for My starlet, the Are 15x7 et 29, and has a 175-55 tyre, wil they rub bad?ThanksOH and it's an ep91 na Quote
NewbieLewby Posted April 2, 2016 Posted April 2, 2016 Depends how low you are If it's only 40 mm or so you should be fine Do a willtheyfit.com Quote
daniel_g Posted April 2, 2016 Posted April 2, 2016 175 on a 7J will have a bit of a stretch so doubt you'll get rubbing.... or traction lol.I run 195 on a 6.5J Quote
richardc9052 Posted April 2, 2016 Posted April 2, 2016 Yeah if theres is rubbing on that setup its because your absolutely slammed without an adj panhard rod and it will only be rubbing on one side lol. they will be spot on mate. Quote
olidaviesuk Posted April 10, 2016 Posted April 10, 2016 Should go fine mate, the amount of stretch you'll have on the sidewalls will be loads so not gonna have square tyre shoulders lol, worst case a light roll of the arches Quote
JayJ Posted April 13, 2016 Posted April 13, 2016 I had 15x7 ET28 with 195/45, coilovers, no panhard rod, no arch work, no rubbing. Quote
MR-2 Posted April 13, 2016 Posted April 13, 2016 Little bit flexible rear without panhard JayJ Adjustable panhard is maybe needed, specially lowered... Quote
richardc9052 Posted April 13, 2016 Posted April 13, 2016 Does the adjustable panhard rod make that much of a difference at tightening the rear end Quote
MR-2 Posted April 13, 2016 Posted April 13, 2016 It's not tightening anything, it's there only for centerin axle and keeping it there. Only need adjusting if chacing riding height much. Quote
daniel_g Posted April 13, 2016 Posted April 13, 2016 Adjustable panhards normally have poly bushes so replacing an old worn unit might tighten up the back slightly. Plus you can get the rear axle 100% centered. Quote
richardc9052 Posted April 13, 2016 Posted April 13, 2016 I know about the adjustment but Daniel got me. Just wouldn't have thought there would be much movement in the panhard rod in the first place. I've fitted one purely to center the axle but they come with polybushes so it was worth the ask lol Quote
daniel_g Posted April 13, 2016 Posted April 13, 2016 There would only be movement if the old bushes were worn Quote
JayJ Posted April 13, 2016 Posted April 13, 2016 Little bit flexible rear without panhard JayJ Adjustable panhard is maybe needed, specially lowered... Haha, adjustable one I meant ;) Quote
