MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 This was my mission, add EE100 Corolla parts to Starlet carburator tank, don't wanna outtank pump or other boot systems. This is silent oem style and no extra problems in MOT. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Little hammering over tank. Flange is oversized for purpose, so swirling pot can be added. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Old flange away. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 New walls inside, fuelgauge sender had to keep, so that must remember to check before welding. I bended walls every direction and welded those together and on to bottom. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Then swirl pot narrowed, too big for my tank hole. Added fuel holes every corner, so my Supra pump don't have to suck air. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Weird position, but flange must be one position and pump hanger can't be different position because of returnpipe and electric connector. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 http://www.mwsteel.eu/en/ Then my friend Joni Marttila TIG welded flange, so it won't leak ever, better choice than me with MIG.He's homesite, amazing tuner Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Then preparation for painting, two layers primer. Too lazy to paint with airgun. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Two layers of top coat, basic dark grey. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Time to think which intank pump to use. Here was choises from up to down.- Supra JZA80 2JZ-GTE - Corolla EE80 4E-FE- MR2 SW20 3S-GE x 2Ended up to small Supra pump, because it fits straight to Corolla hanger and is very good pump under pressure and low volts. Enough good for 500hp little tuned Supra. Even that MR2 n/a pump is good for 245hp Gen3 3S-GTE, but aim is go over that... Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Same size fuel line in Supra as Corolla, also plug is same, Supras wires were thicker so. So fuel line gona be AN6. Fuel rail also standard 4E-FTE, no need for better now. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Hopefully some perverts reads this shit, one post at time, so hard while driving. And target is forged 5E-FTE engine and trackcar to street with sleeper look. Only visual thing gona be rollgage and some low profile external things. Enjoy or hate, feel free to comment Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Then I bougt EP91 4E-FE non abs axle with drumbrakes for 50. Basic mod for P7 owners, so better bushings and GT/Glanza brakes can added. First mod was panhard rod support change. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Not hard job to take away. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Drilled one hole and that was hardest part. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Next cut/paste, 80mm away was my calculation. Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Bye bye old arms, don't tell MOT inspector :/ Quote Link to post Share on other sites
MR-2 Posted April 7, 2016 Author Share Posted April 7, 2016 Test welding Quote Link to post Share on other sites
