I have got a stock ep82 over here. Willing to make it run for 400bhp. Will be needing your help to gather the parts and know about the parts. Can u guys give me a list of aftermarket parts needed for this type of conversions.
Also where i can get this parts directly from shop.
Edited by piashhassan
If your looking for 500hp from a starlet engine you would need to be fairly clued in or know someone who is.
And have rather deep pockets.
Phil
Hello mate as above you wont be making 500hp from an 4efte engine there is other options like 3sgte 2zz or forging an 5efe engine and yes you will need deep pockets!!
Thanks for the suggestions. If not 500hp, i have seen 400hp ones so can it be possible to make it to 400hp one and don't worry about the money
I would like to know from where its best to take the forged engine parts, tdo4 or Gt-28 turbo and all other things which if a list can be suggested it will be better
I'd suggest a very good option for 400hp would be a gtx2863r Garrett
Forged engine stuff beat to go to your best localism tuner and have them do it all for you
Again based on the assumption this build is an all the gear no idea sort of thing
Phil
Edited by Phil
You should edit the title of this thread or your just going to attract all sort of plebs chipping in to say it can't be done etc etc
Make it 400 or just high hp
Phil
Maybe peak power can take 500hp, but block will not last long. You better move at least 4A-GTE transplant. Roadcar and quartermile cars so different world, 500hp fwd is very slippery on normal tarmac, too much...
You won't reach 500bhp with a starlet engine, you'd be best off looking at a different engine set up
Check out socks build thread this will give you some idea
James
There are a fair few starlets with over 500bhp though?
Aye 500 can be done if u have the bank todo it but todo it properly u will be talking over 20k and the actuall drivability of it will be questionable.
