Yea I'm slowly gettin there, but when the car is 150 km away from where I live, it takes a bit longer than usual projects 😊
by the way that td05 manifold is absolute mental, one of my best purchases ever!
The splitter is from an original ep71, just got it refurbished as everything else.. I actually bought the splitter in 2010 for my previous starlet, but sold the car to a kid and the splitter to a friend. And here 6 years after he still had it and bought it back for the same money 😉 Nice to get things storaged.
  • Replies 83
Got a few parts ordered and delivered so the engine can be mounted.
Tial mv-s 38 mm wastegate, should be enough for my hp goal for now.
9CE19980-42CD-4725-B237-1C9040DA1F53_zps
Competition clutch stage 4. Actually I had bought a new sachs standard clutch and got the pressure plate stiffened and ordered a zinter metal clutch plate, but it was out of stock so changed the plans. Should control about 400 hp, but we'll see.
2650FBFD-DA37-413E-AEC8-E1BBBA093BD8_zps
Tried the wheels on this weekend! Looks awesome with the JDM green lugnuts, just need some tires and more low
C5919D19-C00B-4B80-ADC4-57AAB049D8D8_zps
My clutchkit arrived, 212mm competition clutch stage4 from a corolla. Fits my CC flywheel very nice
5787E12D-BB1D-46EF-BAF2-0E8DE132F338_zps
About brakes for a starlet: everything original is apparently not being fabricated anymore, so all of my plans about brakes has to be changed, but then an upgrade is possible. Here is standard ep70 front calipers vs celica at160 gt calipers. Directly bolt on the original hubs, just needs a 7mm spacer behind the disc to olace it in the middle of the saddle. New setup: 243mm vented front discs 😊
ADEF048B-1503-434C-841E-0DB04CDAA2CE_zps
Custom race spec rocker cover with an10 fittings. Cleaned for a new look
24E004DB-7BF6-44AF-919C-A7124B46527A_zps
Edited by PvflindtDK
  • 2 months later...
Long time since something happened. Last time it went a little bad with everything planned, so decided to take a break from the car, to get on track again and get some motivation. Today the engine got so finished that it's ready to come in the car. And i assembled manifold-turbo with wastegate, screamer and downpipe. Think it looks great.
01270576-4749-49EF-BACF-43977A1DD678_zps
FE18F7A3-2CDA-426B-9213-E5C0D961E1CC_zps
Also found out that my new wide wheels don't fit the damn car. So I sold them again to a friend to get some new ones.
Decided to go another way and chose Japan Racing Jr3 in other dimensions than first set. New dimensions will be 7x15 et40 front and 8x15 et25 rear. Colour will be bronze with green lug nuts
DB51ED36-1E74-4936-B9C7-47A19CC0205A_zps
Yeah, it's a bit high offset, but i'm upgrading my brakes to celica brakes in the front, and needs spacers so the discs is centered correctly. So i'm loosing 7mm, plus an extra mm cause the thickness of the brakes. So think it's gonna fit alright 😊
Aaand engine is in!! Have been looking forward to this for so long, and finally it happened. Gonna make something with the rear gearbox mount though, so engine sits straight. Fabricating a front mount too, so it doesn't tilt when boosting.
5D37E01D-A741-46CF-8B6E-41FF71C64A04_zps
Rocker cover needs finish, colour will be wv2 sparkling silver as the engine bay.
A467F6C5-936B-45C7-830F-138BB764460B_zps
Fitted the WEPR manifold, unfortunately an ep70 enginebay is way smaller than ep91, so mods to the lockplate needs to be done. Thinking about creating a new one in alloy.
BCCFDD1C-AD67-4CE1-B467-41F92616DB37_zps
Love that front. Looks mean with the carbon headlight.
B7A3C667-0D80-4394-9C5F-1939F88ABA36_zps
Wiring is next, all brand new
ACFAB1CC-E34F-4A49-8ECE-1A5C39D28D43_zps
Collected a c52 gearbox from a 3e earlier this week, very cheap. Then i just need a blacktop or agze diff and a rebuild, then it's ready for boost.
8AF95A84-2D78-400A-93C8-F0F9C8BA20CD_zps
  • 2 months later...
Long time since something remarkable happened. I sorted a lot of small bits and problems, renewing front brakes, made some wiring inside the car etc.
I made a new front lock plate, so my WEPR manifold with external wastegate fits the engine together with my alloy rad. Not much space in there, but it'll fit.
02FA152E-ABC1-41D5-A8D1-16F5BB1ACD02_zps
31CCFE02-889B-413E-A7FF-2CCD13F4954D_zps
Plate is cut so rad is fitted as a part of the lockplate, it moves the rad about 5 cm more towards the front, and suddenly everything is possible.
D65359C4-848C-40C9-A3F6-4DB5E69CBC44_zps
Not much space, but it's enough. With the original lockplate, the rad covered half of the wastegate outlet
06D216B0-189D-4459-AD4D-7D5A1DCDD9F0_zps
Everything's fitted, locking mechanism fitted the right place and adjusted. Just needs a clean, grinding, polishing and a bit of love, so it looks as new as the rest of the car
85E4E7C3-8CEA-46D9-AD23-057667392700_zps
  • 3 weeks later...
  • 1 year later...
Over a year since last update! I stopped uploading cause the program for uploading pictures decided to stop working. It still doesn’t work, trying to sort it out.
Since last time a lot have happened, also my normal life besides my car. I got 2 kids now, so not much time to spend on the starlet.
I’m almost finished with wiring, it has taken a lot of time and many sleepless nights to figure out how to do it right.
The car is more or less finished outside, I’m still looking for a turbo honeycomb grille and a top spoiler. Wheels fit perfectly, small bits and pieces are fitted.
To do list to crank it for the first time:
-Sort out battery mount
-Make boostpipes (Stainless with visible weldings, clearcoated)
-Exhaust from downpipe, also stainless.
-Last bits of wiring, and connect it to original loom.
I hope to get it finished and running next year. Let’s see how things end up.
