PvflindtDK Posted November 3, 2016 Author Posted November 3, 2016 Yea I'm slowly gettin there, but when the car is 150 km away from where I live, it takes a bit longer than usual projects 😊by the way that td05 manifold is absolute mental, one of my best purchases ever!The splitter is from an original ep71, just got it refurbished as everything else.. I actually bought the splitter in 2010 for my previous starlet, but sold the car to a kid and the splitter to a friend. And here 6 years after he still had it and bought it back for the same money 😉 Nice to get things storaged. Quote
PvflindtDK Posted November 6, 2016 Author Posted November 6, 2016 Just got these bad boys delivered 😊 9x15" in the rear and 8x15" in the front, that's gonna look mean 😎 Quote
ChristopherEP70 Posted November 6, 2016 Posted November 6, 2016 The colour looks the business! Wheels will look pretty cool with plenty of lows Quote
jiggaman_16 Posted November 8, 2016 Posted November 8, 2016 Just got these bad boys delivered 9x15" in the rear and 8x15" in the front, that's gonna look mean I think i like it! Quote
MR-2 Posted November 15, 2016 Posted November 15, 2016 Wow, clean engine. Holy shit, 9" wheels to rear, gona fit like clove with widener arches, what tyres You gona put? Quote
PvflindtDK Posted November 15, 2016 Author Posted November 15, 2016 Actually don't know which tyre i'm gonna use yet, fronts are gonna be 195/50-15, but don't know if the rears should be 205 or 215's. I'll find out when I see how the rims fits the car 😊 Quote
PvflindtDK Posted November 15, 2016 Author Posted November 15, 2016 Got a few parts ordered and delivered so the engine can be mounted. Tial mv-s 38 mm wastegate, should be enough for my hp goal for now.Competition clutch stage 4. Actually I had bought a new sachs standard clutch and got the pressure plate stiffened and ordered a zinter metal clutch plate, but it was out of stock so changed the plans. Should control about 400 hp, but we'll see. Quote
PvflindtDK Posted November 28, 2016 Author Posted November 28, 2016 (edited) Tried the wheels on this weekend! Looks awesome with the JDM green lugnuts, just need some tires and more lowMy clutchkit arrived, 212mm competition clutch stage4 from a corolla. Fits my CC flywheel very niceAbout brakes for a starlet: everything original is apparently not being fabricated anymore, so all of my plans about brakes has to be changed, but then an upgrade is possible. Here is standard ep70 front calipers vs celica at160 gt calipers. Directly bolt on the original hubs, just needs a 7mm spacer behind the disc to olace it in the middle of the saddle. New setup: 243mm vented front discs 😊Custom race spec rocker cover with an10 fittings. Cleaned for a new look Edited November 28, 2016 by PvflindtDK Quote
MR-2 Posted December 5, 2016 Posted December 5, 2016 Looking good, happy to see at somebodys projects goin forward Quote
PvflindtDK Posted February 11, 2017 Author Posted February 11, 2017 (edited) Long time since something happened. Last time it went a little bad with everything planned, so decided to take a break from the car, to get on track again and get some motivation. Today the engine got so finished that it's ready to come in the car. And i assembled manifold-turbo with wastegate, screamer and downpipe. Think it looks great.Also found out that my new wide wheels don't fit the damn car. So I sold them again to a friend to get some new ones.Decided to go another way and chose Japan Racing Jr3 in other dimensions than first set. New dimensions will be 7x15 et40 front and 8x15 et25 rear. Colour will be bronze with green lug nuts Edited February 11, 2017 by PvflindtDK Quote
biggy_ep70 Posted February 21, 2017 Posted February 21, 2017 mhmhmhhmhmhm...i hope the et40 rims will fiti ussually use et's from 30 to 25 Quote
PvflindtDK Posted February 25, 2017 Author Posted February 25, 2017 Yeah, it's a bit high offset, but i'm upgrading my brakes to celica brakes in the front, and needs spacers so the discs is centered correctly. So i'm loosing 7mm, plus an extra mm cause the thickness of the brakes. So think it's gonna fit alright 😊 Quote
PvflindtDK Posted February 25, 2017 Author Posted February 25, 2017 Aaand engine is in!! Have been looking forward to this for so long, and finally it happened. Gonna make something with the rear gearbox mount though, so engine sits straight. Fabricating a front mount too, so it doesn't tilt when boosting.Rocker cover needs finish, colour will be wv2 sparkling silver as the engine bay. Quote
5e colin Posted February 25, 2017 Posted February 25, 2017 could you pm me the link to the rolla clutch as it seems better then mine great progress so far i like Quote
PvflindtDK Posted February 26, 2017 Author Posted February 26, 2017 Fitted the WEPR manifold, unfortunately an ep70 enginebay is way smaller than ep91, so mods to the lockplate needs to be done. Thinking about creating a new one in alloy.Love that front. Looks mean with the carbon headlight.Wiring is next, all brand newCollected a c52 gearbox from a 3e earlier this week, very cheap. Then i just need a blacktop or agze diff and a rebuild, then it's ready for boost. Quote
PvflindtDK Posted May 12, 2017 Author Posted May 12, 2017 Long time since something remarkable happened. I sorted a lot of small bits and problems, renewing front brakes, made some wiring inside the car etc.I made a new front lock plate, so my WEPR manifold with external wastegate fits the engine together with my alloy rad. Not much space in there, but it'll fit.Plate is cut so rad is fitted as a part of the lockplate, it moves the rad about 5 cm more towards the front, and suddenly everything is possible.Not much space, but it's enough. With the original lockplate, the rad covered half of the wastegate outletEverything's fitted, locking mechanism fitted the right place and adjusted. Just needs a clean, grinding, polishing and a bit of love, so it looks as new as the rest of the car Quote
PvflindtDK Posted June 10, 2017 Author Posted June 10, 2017 Thx guys, appreciating the comments! Quote
PvflindtDK Posted August 26, 2018 Author Posted August 26, 2018 Over a year since last update! I stopped uploading cause the program for uploading pictures decided to stop working. It still doesn’t work, trying to sort it out.  Since last time a lot have happened, also my normal life besides my car. I got 2 kids now, so not much time to spend on the starlet. I’m almost finished with wiring, it has taken a lot of time and many sleepless nights to figure out how to do it right. The car is more or less finished outside, I’m still looking for a turbo honeycomb grille and a top spoiler. Wheels fit perfectly, small bits and pieces are fitted. To do list to crank it for the first time: -Sort out battery mount -Make boostpipes (Stainless with visible weldings, clearcoated) -Exhaust from downpipe, also stainless. -Last bits of wiring, and connect it to original loom.  I hope to get it finished and running next year. Let’s see how things end up. Quote
Calum122 Posted August 26, 2018 Posted August 26, 2018 That's really nice. Doing a fantastic job. Would love to see some photos. Â Just upload the photos to Imgur and paste them here. Quote
Socks Posted August 27, 2018 Posted August 27, 2018 If you purchase club membership, you can simply hit the upload button straight into your post! No need for any links or apps! Quote
