Chtec Posted April 19, 2016 Share Posted April 19, 2016 Ok so over the last few days my wideband has been doing some crazy things, first noticed on sunday morning that upon leaving home in the morning the gauge was stuck on lean, 3 dashes, for around 15 mins of steady driving and me flicking the screen in a passive attempt to encourage it back into normality it started reading again but the readings were totally alien to me, and extremely laggy, my setup has been spot on running friendly low 11s at WOT and hovering around 14.7 cruising around. Now at WOT it'll read a dodgy 13 and then when you cruise again it'll sit around 16.5-17, and then sometimes will get itself stuck back on the 3 dashes for a bit. A little concerning now I have no indication of what's going on but I'm confident all is as it should be, no change in running or driving whatsoever so I'm led to a dodgy sensor which I'm waiting on. I've checked all wiring and plugs and all is as good, just curious if anyone else has had similar issues with the aem wideband? I know the sensors need renewing every so often, this ones been in for a good 6 months..? Sent from my SM-G920F using Tapatalk Quote Link to post Share on other sites
Dean_mc88 Posted April 19, 2016 Share Posted April 19, 2016 It may need a reset if that's possible I know I the innovate ones say you should reset the module after so many miles Quote Link to post Share on other sites
starletezy Posted April 19, 2016 Share Posted April 19, 2016 It needs to be recalibrated mate I also own an innovate and that also needs calibrating every couple thousand miles Quote Link to post Share on other sites
Ollieh17 Posted April 19, 2016 Share Posted April 19, 2016 AEMs arent supposed to need calibrating Quote Link to post Share on other sites
Bug679 Posted April 19, 2016 Share Posted April 19, 2016 Aems shouldn't need calibrating is there any warning lights popping up ? Mine has a warning light comes up sometimes I just switch the car off let the Wideband heat up again and alls fine. Sensor shouldn't need replacing after 6 months. Quote Link to post Share on other sites
hopalong_neil Posted April 21, 2016 Share Posted April 21, 2016 Sounds like it's toast.I mistakenly installed mine without wiring and ran car for a few days whilst I was sorting something else.When I finally wired it mine did much the same thing. Replaced sensor and all was well afterwards.Can't remember specific details but there is a test you can do. Think you leave it open to atmosphere and check reading then cover it with a rag soaked in a solvent (can't remember which one) and it should read rich.Worth having a Google for AEM wide band showing lean, all details should be there. Quote Link to post Share on other sites
Chtec Posted April 22, 2016 Author Share Posted April 22, 2016 Cheers guys, I stuck a new sensor in yesterday and all back to normal, it's odd because it doesn't seem like a sensor issue when it reads hit and miss, learn something new everyday! Sent from my SM-G920F using Tapatalk Quote Link to post Share on other sites
Bean Posted April 22, 2016 Share Posted April 22, 2016 I had a sensor die a few years ago too. Quote Link to post Share on other sites
Chtec Posted May 3, 2016 Author Share Posted May 3, 2016 New sensor hasn't lasted very long.. same sort of symptoms, then read fine sometimes until your at full chat where it'll hold for a second then wave goodbye and sweep to full lean - starting to doubt my mounting of it but reassured it's OK seeing how long the first sensor lasted.. new sensor time again lol Sent from my SM-G920F using Tapatalk Quote Link to post Share on other sites
Amjad Posted May 3, 2016 Share Posted May 3, 2016 I was looking to buy an AEM, not so sure after reading this! Quote Link to post Share on other sites
TimD Posted May 3, 2016 Share Posted May 3, 2016 How far down the exhaust is the sensor? Quote Link to post Share on other sites
Duduglanza Posted May 4, 2016 Share Posted May 4, 2016 My aem has been installed for years. Always ran fine. Istall it 35" back from turbo and tilt it a bit so it doesnt get clogged Quote Link to post Share on other sites
RobSR Posted May 5, 2016 Share Posted May 5, 2016 Was going to say about sensor location? If you're running it to near the back of the turbo it'll be getting to hot.. Quote Link to post Share on other sites
