Hi guys want to put in gauges for my glanza v but there's alot to choose from should I go for mechanical or electronic what are the pros and cons and what gauges shouldi get what needs to be kept an eye on I.e oil pressure many thanks
The most important one is a boost gauge, if you're boosted. I personally have a boost gauge and an afr gauge to monitor my fueling.
As for brands, I'd say AEM, but there are plenty more.
Mechanical gauges are plumbed into the source of what your using the gauge for where electrical are just wired to it both are reliable as long as you get a good one don't have to be mad expensive just not chinese rubbish
I use Greddy boost and oil pressure and AEM air fuel
ya can get all the gauges you want on ebay or keep an eye out for second hand ones popping up on here :)
Edited by Bug679
I can't see any of the traders on here doing definitely gauges I seen some on eBay but I don't know if they are copies
Where are people getting there oil pressure from, I have the sender for my guage but I want to use a braided hose with a tee piece I can't find one anywhere to suit the thread of our oil pressure sensor
Im running-
Oil temp-Pro sport
Oil pressure-Pro sport
Water Temp-Pro sport
Boost-Pro sport
Wideband- AEM
as for where to take oil from im using a sandwich plate
