dan106 Posted May 25, 2016 Share Posted May 25, 2016 Well my GT will be my daily again in October, and I think I'm getting old as the vibration is annoying me aha! I go up the m1 everyday and I end up in a lot of trafficI have all yellow poly mounts currently, and was wondering how much softer the jd tuning ones were?Or if I'm better off keeping the poly rear one and tiger sealing the standard front two to stop the engine moving too much but stopping all the annoying vibrations!What do you guys run daily? Quote Link to post Share on other sites
richardc9052 Posted May 25, 2016 Share Posted May 25, 2016 Yellow are like 80 shore You can buy 60a shore polyurethane online and fill standard mounts. JD uses 65a shore I believe Quote Link to post Share on other sites
Ollieh17 Posted May 25, 2016 Share Posted May 25, 2016 I filled my standard charade mounts(oem rubber still in) with caravan sealant. Sounds pikey but no mounts are available and was cheap 60a rating. vibrates more than standard but isn't crazy and feels alot stiffer when it matters Quote Link to post Share on other sites
dan106 Posted May 27, 2016 Author Share Posted May 27, 2016 Sounds like I'll be tiger sealing the two standard ones and keeping the yellow rear one thenI can handle the vibrations it's 20 year old interior panel rattle I can't stand aha Quote Link to post Share on other sites
5e colin Posted May 27, 2016 Share Posted May 27, 2016 im original tester of the jd mounts there very good and cheap for a set Quote Link to post Share on other sites
richardc9052 Posted May 27, 2016 Share Posted May 27, 2016 Dan tiger seal has a much higher shore value than 60a. Let me show you a mount I poured an the stuff is 20 quid delivered. Still have half left after I did 1 set.. I'll get a pic 2 mins Quote Link to post Share on other sites
daniel_g Posted May 27, 2016 Share Posted May 27, 2016 Richard did you remove all the old rubber first?I have the JD ones, theyre good but theyre not hardcore lol. Quote Link to post Share on other sites
5e colin Posted May 27, 2016 Share Posted May 27, 2016 Richard did you remove all the old rubber first?I have the JD ones, theyre good but theyre not hardcore lol. if you want hardcore then get a nylon bush turned down it will shake your eyeballs i had some made years ago Quote Link to post Share on other sites
richardc9052 Posted May 27, 2016 Share Posted May 27, 2016 I removed about 60% of the origin bush just leaving enough to hold the sleeve in place. Then filled around and over it. Quote Link to post Share on other sites
daniel_g Posted May 27, 2016 Share Posted May 27, 2016 That sounds like 1 step away from solid alloy bushes lol.I removed about 60% of the origin bush just leaving enough to hold the sleeve in place. Then filled around and over it.Nice one ive spare mounts here am gonna give it a go Quote Link to post Share on other sites
glanzadude Posted May 27, 2016 Share Posted May 27, 2016 I got the yellow poly bushes and thankgod I did as some owner before me tigersealed the mounts that DIY shit really pisses me off like do it right are don't bother at all. Quote Link to post Share on other sites
glanzadude Posted May 27, 2016 Share Posted May 27, 2016 The yellow polys are ROCK hard if I was to do it again I would go for softer ones are just leave stock but I am happy as got them for free Quote Link to post Share on other sites
dan106 Posted May 27, 2016 Author Share Posted May 27, 2016 So will the jd tuning be more comfortable for daily driving? And mostly for crawling along in traffic as this is where the yellows piss me offI've got all yellow ones and it annoys me now, if my standard ones weren't fucked I'd just put them back in Quote Link to post Share on other sites
glanzadude Posted May 27, 2016 Share Posted May 27, 2016 Well I never tried the jd tunning but well worth it if you don't like the yellows Quote Link to post Share on other sites
richardc9052 Posted May 27, 2016 Share Posted May 27, 2016 The way mine are done is with proper 2 part polyurethane. Just instead of creating a separate mold and pouring them separately I just used the mount as the mold, taped off the bottom and poured as one piece. Completely different to filling with tigerseal or other random sealer Quote Link to post Share on other sites
jezza Posted May 27, 2016 Share Posted May 27, 2016 So will the jd tuning be more comfortable for daily driving? And mostly for crawling along in traffic as this is where the yellows piss me offI've got all yellow ones and it annoys me now, if my standard ones weren't fucked I'd just put them back in Just to clarify on the shore hardness. The Powerflex yellow bushes are 70shore and my kit is 65shore. Not much of a difference but offer a bit less cabin vibration. To get the comfort you are looking for, you would probably be best leaving the bottom mount as it is and replacing the others with new standard mounts. That being said, it's probably going to be more expensive to source new OE mounts. Doing myself out of a sale here!!! Quote Link to post Share on other sites
5e colin Posted May 27, 2016 Share Posted May 27, 2016 So will the jd tuning be more comfortable for daily driving? And mostly for crawling along in traffic as this is where the yellows piss me offI've got all yellow ones and it annoys me now, if my standard ones weren't fucked I'd just put them back in yes more comfy then the yellow polys Quote Link to post Share on other sites
Ollieh17 Posted May 27, 2016 Share Posted May 27, 2016 I got the yellow poly bushes and thankgod I did as some owner before me tigersealed the mounts that DIY shit really pisses me off like do it right are don't bother at all.Whats wrong with DIY. Just because you couldn't cope with the harness etc doesnt mean it didnt work well for the person before. Tigerseal isnt the best stuff granted Quote Link to post Share on other sites
glanzadude Posted May 27, 2016 Share Posted May 27, 2016 (edited) ^^^^ RELAX didnt mean to upset you. Not saying tigerseal won't and didn't do the job but just don't like it. Do it right are don't bother at all. You ok now lolJust looked at your comment and I understand you using tigerseal on your mounts but I am talking about starlets Edited May 27, 2016 by glanzadude Quote Link to post Share on other sites
Bug679 Posted May 27, 2016 Share Posted May 27, 2016 Don't see the problem with the yellow mounts at all have them in awhile on me daily and doesn't bother me at all love them really 🤗 Quote Link to post Share on other sites
Whitenoize Posted May 27, 2016 Share Posted May 27, 2016 Don't see the problem with the yellow mounts at all have them in awhile on me daily and doesn't bother me at all love them really 🤗 I'm the exact same mate I've had them on every starlet I've had and it didn't bother me one bit I've seen people on here complaining that the cabin vibrates so much it shakes all the interior loose and the rear view mirror shakes etc Quote Link to post Share on other sites
5e colin Posted May 27, 2016 Share Posted May 27, 2016 I'm the exact same mate I've had them on every starlet I've had and it didn't bother me one bit I've seen people on here complaining that the cabin vibrates so much it shakes all the interior loose and the rear view mirror shakes etc wow this thread went sour quick and indeed yellows make a dildo out of a starlet that will rattle al the trim loose over time Quote Link to post Share on other sites
Whitenoize Posted May 27, 2016 Share Posted May 27, 2016 wow this thread went sour quick and indeed yellows make a dildo out of a starlet that will rattle al the trim loose over time wasn't being sour at all mate just giving a different opinion Quote Link to post Share on other sites
Bug679 Posted May 27, 2016 Share Posted May 27, 2016 I'm the exact same mate I've had them on every starlet I've had and it didn't bother me one bit I've seen people on here complaining that the cabin vibrates so much it shakes all the interior loose and the rear view mirror shakes etc Seen people saying that to man ,fair enough it does shake quite a bit but I can't see them shaking the car apart lol Quote Link to post Share on other sites
