morgan Posted June 29, 2016 Share Posted June 29, 2016 Okay so my car is going in to be getting g an ecu and mapped in 3 weeks and was told to get a FPR so they can make sure everything g is safe.Was going to go with the tuning developments kit, anyone had any problems with these or recommend anything else?When I get it just want to know how to install and set it up to stock pressure Need all the help I can please Thank you Joe Quote Link to post Share on other sites
Jamie_VF22 Posted June 29, 2016 Share Posted June 29, 2016 Here you mate http://www.toyotagtturbo.com/forums/showwiki.php?title=How+to+Install+a+Fuel+Pressure+Regulator Quote Link to post Share on other sites
morgan Posted June 29, 2016 Author Share Posted June 29, 2016 Nice one mate thanks.Do you know if the tuning developments Fuel pressure regulator is any good ? Looking to make 200bhp Quote Link to post Share on other sites
5e colin Posted June 29, 2016 Share Posted June 29, 2016 you dont need 1 for a 200bhp uprate the pump instead Quote Link to post Share on other sites
Jamie_VF22 Posted June 29, 2016 Share Posted June 29, 2016 As above you wont need one if you only want 200 bhp no point just get a walbro 255 fuel pump Quote Link to post Share on other sites
morgan Posted June 29, 2016 Author Share Posted June 29, 2016 Hummm was told by the tuner it would be needed. Quote Link to post Share on other sites
Ollieh17 Posted June 29, 2016 Share Posted June 29, 2016 If the tuner wants one, fit one Quote Link to post Share on other sites
morgan Posted June 29, 2016 Author Share Posted June 29, 2016 Anyone used the one tuning development sell ? Quote Link to post Share on other sites
5e colin Posted June 29, 2016 Share Posted June 29, 2016 Hummm was told by the tuner it would be needed. why ??? are you going the fcd/rrfpr route ??? if its getting mapped then its a waste of money because it wont be needed Quote Link to post Share on other sites
morgan Posted June 29, 2016 Author Share Posted June 29, 2016 Just going for a piggy back ecu. Quote Link to post Share on other sites
Gainzy Posted June 29, 2016 Share Posted June 29, 2016 Of course the tuner will want you to buy one it's good business, seen builds for many years running stock fpr 250 plus plus I run over 200 with no aftermarket fpr. It's all about the map Quote Link to post Share on other sites
morgan Posted June 29, 2016 Author Share Posted June 29, 2016 He said he will map it without one but said they die off pretty early, don't want to be spending money I don't have to Quote Link to post Share on other sites
Ollieh17 Posted June 29, 2016 Share Posted June 29, 2016 I dont see anything wrong with having one. Lots of things are not really needed. They are 20 od years old now, plus fine tuning fuel pressure in future Quote Link to post Share on other sites
5e colin Posted June 29, 2016 Share Posted June 29, 2016 stock fpr is good for 1.2bar tdo4 ( more i cant comment ) Quote Link to post Share on other sites
triple j Posted June 29, 2016 Share Posted June 29, 2016 No problem with the stock fpr its the stock fuel pump I would be worried about, as said above if the tuner wants one let him have it. Quote Link to post Share on other sites
hopalong_neil Posted June 29, 2016 Share Posted June 29, 2016 (edited) My stock fpr ran 1.4 bar on a td04 with no issues, stock pump too Edited June 29, 2016 by hopalong_neil Quote Link to post Share on other sites
5e colin Posted June 29, 2016 Share Posted June 29, 2016 jeeeez al these boys saying go for it because the incompetent tuner says so fuck it go els where just tel them to learn to map better Quote Link to post Share on other sites
Ollieh17 Posted June 29, 2016 Share Posted June 29, 2016 Whats the advantage of keeping a stock one over a adjustable? Bearing in mind one is 20years old? Havent mentioned anything about deviating away from stock fuel pressure... Quote Link to post Share on other sites
5e colin Posted June 29, 2016 Share Posted June 29, 2016 (edited) what do you think because its 20 years old it works less ??? the answer is no she works just the same as a new 1 no more no less FACT !!!!! you ever hears of 1 failing ??? me no not of 1 on any car what so ever Edited June 29, 2016 by 5e colin Quote Link to post Share on other sites
Ollieh17 Posted June 29, 2016 Share Posted June 29, 2016 To add, i had issues with rich running after fitting a walboro to my V. This cured after the work i did where nearly everything was changed including adding a fpr. Now i cant say it was specifically the fpr that cleared it. But, same issue with my GTti, aftermarket pump and an old standard fpr can't cope cause rich conditions. Fitted a sard and the problem has improved, still slight issue with the return pipe being a small diameter Quote Link to post Share on other sites
Ollieh17 Posted June 29, 2016 Share Posted June 29, 2016 Fact incinuates you have evidence to prove?have evidence on a gauge of fuel pressure from new and 20 years down the line? Quote Link to post Share on other sites
5e colin Posted June 29, 2016 Share Posted June 29, 2016 (edited) Fact incinuates you have evidence to prove?have evidence on a gauge of fuel pressure from new and 20 years down the line? sure al your regs are still doing the same lads even on some of our glower boys 27 years later !!! my glower does exactly the same as my quad it either works perfect or feul be squirting aaal over and you be going no where attal exept calling fire brigade Edited June 29, 2016 by 5e colin Quote Link to post Share on other sites
daniel_g Posted June 29, 2016 Share Posted June 29, 2016 Its personal preference.There are a lot worse / less important / pointless parts to be spending money on.An adjustable FPR can be pretty key when setting up a wideband. Quote Link to post Share on other sites
jamesglanza Posted June 30, 2016 Share Posted June 30, 2016 I have had 2 cheap afpr fail but never a stock regulator. My advice would be to spend a little more money on a good reputable brand rather than Chinese non branded part. Aem, fuel lab, aeromotive, turbosmart, genuine sard stuff is all good. Stay away from the sytec imo. Quote Link to post Share on other sites
morgan Posted June 30, 2016 Author Share Posted June 30, 2016 Thanks for your help everyone Quote Link to post Share on other sites
