Legend009 Posted September 12, 2016 Share Posted September 12, 2016 Can the 5e pistons be used on a 4efte engine??? If yes what are the consequences?? Quote Link to post Share on other sites
SpikeyJp_68 Posted September 12, 2016 Share Posted September 12, 2016 They're higher compression so you'd have to run lower boost Quote Link to post Share on other sites
SpikeyJp_68 Posted September 12, 2016 Share Posted September 12, 2016 Found this on ausstarletclub from androo26. You can see the different comp. ratios Quote Link to post Share on other sites
Legend009 Posted September 13, 2016 Author Share Posted September 13, 2016 Okay thanks man. Il have to start lookin for the pistons Quote Link to post Share on other sites
richardc9052 Posted September 13, 2016 Share Posted September 13, 2016 You would be looking at an approx comp ratio of 8.9:1 with 5efhe pistons or 8.5:1 with 5efe pistons Quote Link to post Share on other sites
5e colin Posted September 13, 2016 Share Posted September 13, 2016 you can boost safe 10 psi or so no bother mabie more if you get a pro map i boosted a gi block with mk1 4efe pistons at a bar ( there the highest dome pistons for our engines ) Quote Link to post Share on other sites
MR-2 Posted September 13, 2016 Share Posted September 13, 2016 You can do 4E-FTE pistons from 5E pistons, budget tuning. I have machined those and ceramic coated those. Basically factory do one piston mold and they machine pistons for every motor. Can take picture later about my pistons... Quote Link to post Share on other sites
Legend009 Posted September 15, 2016 Author Share Posted September 15, 2016 So the 4efe pistons can give boost of 1 bar? Thats the mk1 Quote Link to post Share on other sites
5e colin Posted September 16, 2016 Share Posted September 16, 2016 it can yes ( gen1 ) but its extreme it's a ticking time bomb that could go any sec ( mine lasted 6 months i think it was ) before piston swap if you want longevity then do 10/11psi Quote Link to post Share on other sites
Legend009 Posted September 17, 2016 Author Share Posted September 17, 2016 Okay. Leme way the options first and see wat i get here Quote Link to post Share on other sites
richardc9052 Posted September 17, 2016 Share Posted September 17, 2016 If your gonna go the way of using oem pistons go 4efte. If you must use n.a pistons go for 5efe as they will give the lowest compression of the lot. Quote Link to post Share on other sites
gorganl2000 Posted September 17, 2016 Share Posted September 17, 2016 sorry for the late drop in...but i'll add my two centsi've personally been involved in running 5efhe pistons in a 4efte with gt rods----stock build....it was an experiment at first as we had no idea what would happen and how reliable it would be .....it turned out to be very reliable and quite responsive off boost too this car ran a td04L with emu and was tuned to run 18/20psi on pump gas....ran well for a long time it can be done....it just needs to be tuned properly---fuel AND ignition (using some sort of detonation listening device) Quote Link to post Share on other sites
Legend009 Posted September 25, 2016 Author Share Posted September 25, 2016 That sounds nice. Leme try spurce them out and give it a try. Will update once i get the parts Thanks for the knowledge guys. Quote Link to post Share on other sites
bajansuperman Posted October 27, 2016 Share Posted October 27, 2016 sorry for the late drop in...but i'll add my two centsi've personally been involved in running 5efhe pistons in a 4efte with gt rods----stock build....it was an experiment at first as we had no idea what would happen and how reliable it would be .....it turned out to be very reliable and quite responsive off boost too this car ran a td04L with emu and was tuned to run 18/20psi on pump gas....ran well for a long time it can be done....it just needs to be tuned properly---fuel AND ignition (using some sort of detonation listening device)Currently running 10psi in my 5e block think comp is around 210 greddy turbo needs a porper clutch to step up but these set ups just need fuel Sent from my SGH-M919 using Tapatalk Quote Link to post Share on other sites
gorganl2000 Posted October 29, 2016 Share Posted October 29, 2016 Currently running 10psi in my 5e block think comp is around 210 greddy turbo needs a porper clutch to step up but these set ups just need fuelSent from my SGH-M919 using Tapatalk the more boost you run, the more important it will be to tune ignition as well....especially given our local gas quality you are probably at or very near the maximum you can do without further upgrades (if you dont already have some of this stuff installed )--piggyback/standalone, fueling, plugs, injectors, clutch, boost controller, etc Quote Link to post Share on other sites
