Iwan-g-g Posted November 7, 2016 Posted November 7, 2016 I'm just after a bit of advice, I was driving on the flyover doing about 60 in 4th gear overtaking and the boost gauge showed around 0.9 bar and it hit fuel cut and one hell of a judder.The only mods On my glanza is a Arc top mount intercooler, decat, 3" exhaust. Standard actuator. Any ideas what it could be? Thanks in advance Quote
Starlet__SR Posted November 7, 2016 Posted November 7, 2016 Boost creep causing fuel cut. If you're still on the standard wastegate its gonna keep happening i'm afraid. Quote
Iwan-g-g Posted November 7, 2016 Author Posted November 7, 2016 So if I put a hks adjustable actuator on do you think it'll stop boost creep? Quote
littlegreenmonster Posted February 10, 2017 Posted February 10, 2017 Bump on this thread!! I recently bought a gt and if im crusing along its fine but when i put my foot down it jolts and splutters, does this sound like fuel cut to everyone else Mods are arc top mount and a hks system from cat backThanks in advance Quote
wakeabby14 Posted February 10, 2017 Posted February 10, 2017 So if I put a hks adjustable actuator on do you think it'll stop boost cre Have you got an aftermarket ECU as if not that will be one of the reasons you will get fuel cut, also the standard CT9 will boost creep quite a bit anyway, You could always port your CT9 wastegate to help the issue a bit but it will still creep at this time of year due to the cold air. Quote
crispyeel Posted February 10, 2017 Posted February 10, 2017 Exactly the issue I had before I changed to the CT12 Porting of the CT9 wastegate can help but probably wont completely stop the fuel cut Best bet is to weld the wastegate closed and fir an external wastegate (Tial or equivalent) and fit emanage blue or similar Quote
