SpikeyJp_68 Posted November 27, 2016 Posted November 27, 2016 Read a few bits about this before but never got a definitive answer. Is a FTE crank pulley 100% needed on a turbo engine ? I know the FTE ones are harmonically balanced but what happens if I stick with the FE one ? Quote
Starlet__SR Posted November 27, 2016 Posted November 27, 2016 Mixed opinions on this. Me personally would stick with the FTE pulley as it's dampened. Have a read of this http://www.atiracing.com/products/dampers/damper_dinan.htm Quote
gorganl2000 Posted November 27, 2016 Posted November 27, 2016 (edited) i've used the 4efe crank on both a 4efte and 5efte with no problems over a number of years Edited November 27, 2016 by gorganl2000 Quote
SpikeyJp_68 Posted November 27, 2016 Author Posted November 27, 2016 Mixed opinions on this. Me personally would stick with the FTE pulley as it's dampened. Have a read of this http://www.atiracing.com/products/dampers/damper_dinan.htmDampened that's what I was looking for. Read through that, sounds a bit worrying but just heard of people doing it before with no problems i've used the 4efe crank on both a 4efte and 5efte with no problems over a number of yearsWell that's good to hear. Would save me getting and replacing it with an FTE one Quote
SpikeyJp_68 Posted November 28, 2016 Author Posted November 28, 2016 This is my 4efe one. Looks to be dampened judging by the rubber piece ? Quote
Rob H@RCH Engineering Posted November 28, 2016 Posted November 28, 2016 4efe ones are dampened too, I run one on mine with no issues at all. Quote
5e colin Posted November 28, 2016 Posted November 28, 2016 4efe ones are dampened too, I run one on mine with no issues at all. 4efe ones are dampened too, I run one on mine with no issues at all. Quote
gorganl2000 Posted November 28, 2016 Posted November 28, 2016 plus it seems like a few persons have added turbos to their n/a 4efe---maybe some run the engine as is with the 4efe crank pulley Quote
SpikeyJp_68 Posted November 28, 2016 Author Posted November 28, 2016 4efe ones are dampened too, I run one on mine with no issues at all.If the wizards can do it, it will do for me Quote
SpikeyJp_68 Posted November 28, 2016 Author Posted November 28, 2016 plus it seems like a few persons have added turbos to their n/a 4efe---maybe some run the engine as is with the 4efe crank pulleySeems to be done quite often in that case. A bit off topic here, but I take it the advantages are minimal of running a lighter (4efe) pulley as compared to the heavier (4efte) pulley ? Quote
Rob H@RCH Engineering Posted November 29, 2016 Posted November 29, 2016 You would not see any gains no, but the thing I like is because I'm running electric power steering I could remove the outer part of the pully as I dont need it 👍😀 You would not see any gains no, but the thing I like is because I'm running electric power steering I could remove the outer part of the pully as I dont need it 👍😀 Quote
5e colin Posted November 29, 2016 Posted November 29, 2016 The Na pulley is like 400grams lighter this with a lighter flywheel will make it rev faster, then onto of that do robs pws delete you will notice instantly howmuch faster the revs climbe Quote
gorganl2000 Posted November 29, 2016 Posted November 29, 2016 You would not see any gains no, but the thing I like is because I'm running electric power steering I could remove the outer part of the pully as I dont need it You would not see any gains no, but the thing I like is because I'm running electric power steering I could remove the outer part of the pully as I dont need it Quote
SpikeyJp_68 Posted November 29, 2016 Author Posted November 29, 2016 Off topic again I know but how is it with no power steering ? Better control ? Just don't like thinking of parking Quote
Rob H@RCH Engineering Posted November 29, 2016 Posted November 29, 2016 I still have power steering but an electric pump not the one on the engine! Quote
