funny onion Posted December 19, 2016 Posted December 19, 2016 Hi everyone, does anyone know if a EP82/EP91 chassis front anti-roll bar will fit an EP70? I have one sat about but I'm not convinced it will fit, not offered it up yet but definitely don't think it will fit. If not, can anybody recommend where to get an EP71 anti-roll bar? Cheers! Quote
MR-2 Posted December 19, 2016 Posted December 19, 2016 Buy and test Wanna know also where and what to buy my boxy Quote
funny onion Posted December 19, 2016 Author Posted December 19, 2016 haha if I find one i'll let you know! Quote
kbond Posted December 19, 2016 Posted December 19, 2016 No it doesn't I tried when I had mine, isn't far off though Quote
MR-2 Posted December 19, 2016 Posted December 19, 2016 No it doesn't I tried when I had mine, isn't far off thoughDamn, what was biggest problem, middle tunnel maybe, that was main problem when I tryed AE82 Gti farb, otherwise no problem maybe. Didn't want to cut tunnel bigger, have to hunt TRD arb somewhere if possible... Quote
funny onion Posted December 20, 2016 Author Posted December 20, 2016 No it doesn't I tried when I had mine, isn't far off though Yeah what was the issue? would it be modified to fit do you think? Quote
MR-2 Posted December 20, 2016 Posted December 20, 2016 This is my Corolla 23mm arb, hollow bar.Are EP82/91 Whiteline and TRD arbs made of hollow pipe? And normal Glanza arb is something 18mm and maybe solid/full bar then or hollow?Asked one place here in Finland and they make arbs, maybe that is my route to solve this problem... Quote
glanzadude Posted December 20, 2016 Posted December 20, 2016 my whiteline rarb is way to heavy to be hollow so i am sure same with the other roll bars Quote
MR-2 Posted December 20, 2016 Posted December 20, 2016 Corolla arb is hollow for sure, can feel it in my hands. So is aftermarket arbs too heavy for light EP70/71, GT and Glanza weights more but light cars anyway?That customs place don't have hollow bars :/ Custom bars are 250 euros ~ 200 pounds, of taking more it drops. Or should I mod my floor to fit Corolla bar... Quote
turbo Grant Posted December 23, 2016 Posted December 23, 2016 I fitted an ep82 one on my ep70. I had to weld some extensions on the end of the bar. So that you can bolt the drop links on. Ran that for a while till I got hold of a GAB 24mm one Quote
MR-2 Posted December 23, 2016 Posted December 23, 2016 I fitted an ep82 one on my ep70. I had to weld some extensions on the end of the bar. So that you can bolt the drop links on. Ran that for a while till I got hold of a GAB 24mm oneThanks, I got that info also from Harold van Erven. Have to hunt newer farb then and mod links. Quote
Stu Posted December 24, 2016 Posted December 24, 2016 There's a few guys over here in New Zealand with Turbo S and Si front sway bars for sale if you wanted a direct fit. Quote
adzy Posted December 24, 2016 Posted December 24, 2016 Are EP82/91 Whiteline and TRD arbs made of hollow pipe? And normal Glanza arb is something 18mm and maybe solid/full bar then or hollow?Asked one place here in Finland and they make arbs, maybe that is my route to solve this problem...I've a trd one on my 91 and they're hollow, standard glanza one is solid.Noticed a big Difference in weight between them Quote
MR-2 Posted December 25, 2016 Posted December 25, 2016 There's a few guys over here in New Zealand with Turbo S and Si front sway bars for sale if you wanted a direct fit. Have to consider posting costs first, don't sound so cheap to get one to Finland from New Zealand Quote
