nope not on stock ecu thats fecking crude cristal yoke
buy P&P if wanted to ho higher but there is no point with stock intake manifold as its a restriction for high rpm anyways
why do you wanna raise anyways whats your setup ???
You'd need to look at spending some money on the head if you're gonna go revving higher than the limit. These engines arent designed for high revs from a standard point of view.
Actually guys i got a ported intake and a custom manifold with tdo4 turbo with 10lbs of boost. I'm looking to get Fcd to run a bit higher boost any suggestions also on how much i can run safely with fcd? I wanna raise the rpm limit cause its cheap to do and i could do it at home
To Gain What?
4000rpm to 7500rpm is a decent power band that the td04 gives quite nicely.
A decent map or boost controller would give you much better gains in powerband without risking/wearing an engine faster, faffing around getting 500 more revs.
oh ok thanks for the advice. i am going to buy an fcd and install it. Any idea on how boost i can run safely with an fcd installed with my current setup?
why you say that? Dont they work?
you need to do some research on parts before installing
its the opesit of what you tink they work to well !!! before getting 1 of them a wideband / egt / and knock kit is on order
